Cribbage Boards:
Gallery for samples created from Design and Make 3D Machinist or using Design & Make projects
Moderator: Todd Bailey
rdhharm
Re: Cribbage Boards:
Post by rdhharm »
Thkoutsidthebox wrote:Those boards look really great. Really really great. :)
Rick
rdhharm
Post by rdhharm »
Here are pictures of my lastest cribbage board.
Rick
Phil
Post by Phil »
Very nice work. I like your web site too. Is your web site generating much business?
rdhharm
Post by rdhharm »
Phil
Thanks for the kind words
The web site has brought a little business but this is a hobby and I am sure it could bring more if I wanted to push it that way.
Rick
Greasetattoo
Post by Greasetattoo »
Rick,
When its not a hobby, then it becomes work...
Phil
Post by Phil »
Rick, the quality of the cut on the background of the horse inlay is exceptional. What bit did you use and what was your stepover? Was there much cleanup after the machining?
rdhharm
Post by rdhharm »
Phil,
What I use is a 3/32" ballnose cutter and tell the software it is a 1/16" ballnose and the stepover is 5%. No I did not sand this at all after it was cut but in trade of not sanding it will take a little time to cut.
Rick
calgrdnr
Model of CNC Machine: ShopBot prt with 4g upgrade
Post by calgrdnr »
Exceptional as always, thanks for showing off... :P it is always a pleasure to see your work
thanks again for sharing .
js11110
Post by js11110 »
Very nice job!
Jason
The Official Vectric Cartographer
You are limited only by your imagination
BobF
Post by BobF »
Very nice Rick.
Do you cut the center out separately and instal afterward?
BobF
BobF
Post by BobF »
rdhharm wrote:Phil,
Rick
Rick,
Why use a 3/32" ballnose and tell the software it is 1/16" with 5% stepover? Wouldn't setting 3/32" and a stepover with the same distance work just as well?
Excel tells me that 5% of 1/16 is 0.003125 and 3% of 3/32 is 0.002813.
I
BobF
cas17013
Post by cas17013 »
I have been doing the same thing carving lithophanes, By lying to the software about the bit size you can get a slightly different effect in the the carving that manipulating the stepover alone cannot do. You just have to visualize how the difference in tools will actualy carve the material, and choose what you tell the software accordingly. I first did this on a litho that did not carve well with an engraving bit... Having nothing to lose, I ran the toolpath again using a different bit, and was pleased with the result. Ever since I have been slowly figuring out how to use this to my advantage. With my lithos, I have found using a slightly larger bit than specified in the software still gives good detail, but slightly smooths the carving which many times gives a better machining job on tricky materials. There is a loss of real crisp features, but if the material cannot hold that detail, and have a good finish ther is no real gain in the finished project.
Chris
gravirozo
Post by gravirozo »
hi
larger bit as given to the program, will gives sharper edges...smaller bit gives more rounded...
and i fully agree the statement about sanding... the extra time on milling come back with no sanding...
rdhharm
Post by rdhharm »
Thanks for the kind words guys.
Bob I carve the models and install after. And I guess you could set the stepover as you have it but I am one of the those guys if it is not broke don’t fix it.
Rick
BobF
Post by BobF »
Thanks for the replies.
Just my curriosity.
This is something I have not tried, but looks like I should.
I could see when I did the math that you cannot get exactly the same amounts because the program only allows you to put in the percentage. I can't see in my head yet what the difference would be, but I can't argue with Rick's results. As Rick said, if ain't broke don't fix it.
BobF
