PP for Chinese machine with DSP?
What PP are people using with Chinese machines with the DSP controller?
Got a new user here locally with a new Chinese machine that needs a bit of a hand getting started.
Greg
Greg
- Model of CNC Machine: CAMaster 508 ATC
Re: PP for Chinese machine with DSP?
what is the file extension of any other file he can import? .tap?
- DJ-Bino
- Model of CNC Machine: Versatil 1800
Hello Greg
here are the PP's for China DSP, NC-Easy, and CNC-WOOD
the allways write in German an the
Units = mm you can edit it it's verry
simple.
I have 4 PP's in the zip-File
one for Cut2D, one for Cut3D
one for VCarvePro and one for
PhotoVCarve
sorry for my bad englisch
DJ-Bino
simple.
PhotoVCarve
DJ-Bino
- PP_NC-EASY_DSP.zip
- (5.81 KiB) Downloaded 1170 times
best regards
DJ-Bino
DJ-Bino
Has not succeeded getting anything into it as yet. Hope to at least get him started.cabnet636 wrote:what is the file extension of any other file he can import? .tap?
Do you use the DSP controller? What PP do you use?
Greg
Thanks for that DJ-BinoDJ-Bino wrote:Hello Greg
I output some code with this PP and both Mach3 and NCplot found errors in it.
I realise of course, it was not designed for those programs but wondered why they found illegal lines in it.
From what I remember from my one time using the DSP, the code was very simple without much preamble.
This machine has no toolchanger and the DSP does not control spindle speed AFAIK
Thanks again, Greg
- DJ-Bino
Hello Greg
Mach3 and NC-Plot have another format
and then the error lines are correct
The PP's are working fine with China-DSP 128MB and lower
also work with NC-EASY / CNC-GRAF and CNC-WOOD
The China Maschine can be controlled the Spindle an
the toolchange command goes.
for more information you can look
here write him a PM or an E-mail
http://www.cnc-hotspot.de/index.php?page=User&userID=5
Daniel's englisch is verry good
______________________
best regards
DJ-Bino
DJ-Bino
Thanks DJ-Bino
I am off to visit this machine today so I hope we have success.
Let you know how I got on.
Greg
Greg
I can report that we got the machine singing along nice.
Found that the PP "G-code Arcs (mm)(*.tap)" worked just fine.
Decided I don't like the DSP controller much.
Don't get the visual feedback of what the machine is up to and about to do like you do with Mach3.
So all in all it was a successful visit. Thanks all for the help.
Greg
Greg
- Model of CNC Machine: 1325 wood router
hey good day, i purchased a machine from omni in china anf im currently using Vectric aspire software, im trying to find a post processor for the machine, 4 axis rotary device and the 3 axis
Looks like those machines use the Syntec controllers so I'd start with one of those post processors.
- Mark
- Vectric Staff
Hello,
The post processors that are most like to work for you are the "DSP ATC Arcs (mm)(*.tap)"
or the one of the "NC Studio" post processors.
I hope that this helps.
Hi Mark, Is that correct for Lenroy? The original post was about DSP controllers but from what I can see Lenroys' machine uses a Syntec controller.
my machine uses DSP controller as well, but im not seeing a post processor for the 4th axis attachment in aspire
i email Vectric aspire owners to ask them about my problem and i was told to A sample of rotary code that runs on the machine
and The code format document. but im new to the cnc world, dont know how to acquire either one of those two things
