Clock Face - Spacing the numbers around a circle
Postby solodotcom » Tue Oct 07, 2008 3:23 pm
Using Vcarve Pro, I'm trying to design a clock face and am having some difficulty getting the numbers spaced out correctly around a circle. Using the text box I typed the numbers from 1 - 12 with a space between each number. I then created a circle and aligned the text to the circle and havent' been able to keep the 12 and the 1 from touching as the numbers are spaced out around the circle. Really new to Vcarve. Thanks for your suggestions.
solodotcom
Postby 10cop » Tue Oct 07, 2008 4:02 pm
hello,
Here just my personnal experience.
I start like you and then convert text to curve.
I move each letter manually to get the result I want.
Maybe someone have a better - quiker idea ! ?
bye
I had own a land rover, I use Vcarve but I speak english like a French guy, please apology.
10cop
Postby Greasetattoo » Tue Oct 07, 2008 4:40 pm
Use the copy along vectors button!
Search for it in the help section!
Works like a charm!!!
Greasetattoo
Postby RickD » Tue Oct 07, 2008 10:56 pm
I would make a circle the size you want the number to fit in ,then copy the vectors 11 times and then put the numbers in and delete the circles.
RickD
Postby knighttoolworks » Tue Oct 07, 2008 11:20 pm
RickD wrote:I would make a circle the size you want the number to fit in ,then copy the vectors 11 times and then put the numbers in and delete the circles.
this is the best method it works very well.
knighttoolworks
Model of CNC Machine: shobot 48x96
Postby Greasetattoo » Wed Oct 08, 2008 12:02 am
Copy along vectors is the correct way to do it, and the probably the easiest.
It would space your numbers perfectly..
Believe me!
Give it a try....
Do illiterate people get the full effect of Alphabet Soup?
Greasetattoo
Postby olf20 » Wed Oct 08, 2008 12:56 am
Hi all, hope everone is doing well!!
I've been wondering how to do this also.
I just tried doing it the way Geasetatto described.
It works GREAT!!
Soooooo easy with just a few minutes of practice.
Thanks!!
olf20
olf20
Postby moto633 » Wed Oct 08, 2008 2:35 am
I like soup.
Hey did any one check out the dial Grease did?
Seems like that would be the way to go....... But how would you keep the numbers vertical?
Nick
moto633
Postby Greasetattoo » Wed Oct 08, 2008 2:25 pm
Hey Nick and all,
Well, there is a answer for that one too!..
Just uncheck the "align vectors to curve" and that should keep them vertical!
Man, Vectric has an answer for everything, almost...
Why is the man who invests all your money called a broker?
Greasetattoo
Postby solodotcom » Wed Oct 08, 2008 3:50 pm
Thanks for the help! Is there a manual that just goes over each feature of the program with maybe some examples?
solodotcom
Postby Greasetattoo » Wed Oct 08, 2008 7:48 pm
Ummm, maybe the help file, located on the top menu!
Greasetattoo
Re: Clock Face - Spacing the numbers around a circle
Postby hoops10 » Sat Jul 22, 2017 4:55 pm
I know this thread is old but I cannot seem to get the clock numbers to align correctly. I have tried the 'Copy Along Vectors" button but with no luck. I want to create a clock that is 20" in diameter with an inner ring of 15". I then want the numbers to be attached to both rings (because they will be essentially cut out so the rings will be holding them in place.) I create two circles, one with a radius of 10" and then other with a radius of 7.5". I then create a text box and type all the numbers (12 to 11, putting a space between them.) Here is where I am stuck. I have tried 'Copy Along Vectors" but it just makes a bunch of copies of all the numbers I typed in along the inner circle, thus looking like chaos. I guess I want to grab the numbers I have and 'bend' them along the inner circle. I have been messing with this for hours, please help. Thanks.
hoops10
Postby dwilli9013 » Sat Jul 22, 2017 5:06 pm
Look up the buttons and their usage in the help file. Also watch the attached screen shot tutorial. These two will get you where you need to be.
D-Dub
Dwayne
Dwilli
dwilli9013
Postby highpockets » Sat Jul 22, 2017 5:52 pm
Hoops10,
Try this thread. You need to break the numbers up and position each one.
viewtopic.php?f=2&t=26826&p=193086#p193086
Postby hoops10 » Sat Jul 22, 2017 6:28 pm
Posted before I saw some replies, my bad. I used Bill's method and it seems to have worked. Another question though, is there any way to align the numbers of the clock onto the inner circle curve? That way I can offset them as much as needed? If I try to use Text on a Curve, it just takes the number and places in at the bottom of the curve, very frustrating. Thanks.
hoops10
Next
Return to VCarve - General
Users browsing this forum: Rcnewcomb and 21 guests
