Visiting 3D carving
scotttarnor
Visiting 3D carving
Post by scotttarnor »
Hello, I was attempting to set up a 3D carving this evening, The tutorial videos made it look fairly straight forward but I believe I am missing a step or two on the clean up of the final finish tool path , it looks a little rough to me. I have attached my file for assistance.
Thank You
Scott
deer attempt.zip
(2.43 MiB) Downloaded 103 times
Scott T
@scottscnc
Re: Visiting 3D carving
Post by highpockets »
Use Ball Nose cutters and reduce the step over, especially on the finishing toolpath, try 8%
Can't upload the file, it's just over sized, even zipped, but here are the tools and setting I used.
Created a bounding box around job and Vector Boundary around model
The other thing to watch out for is the size of the model in relation to the material. The smaller the model is in relation to the material the more pixels are being wasted and the resulting model will be lower resolution than it would otherwise be.
The major issue here though, as stated previously, is the stepover is way too big on the finishing pass.
scotttarnor
Thank You highpockets and Adrian, Hopefully I can try again after work tonight.
Scott T
@scottscnc
Jan.vanderlinden
Model of CNC Machine: Xcarve
Post by Jan.vanderlinden »
On thing that I have started doing is to make a second finish pass with a smaller cutter and stepover
1) Roughing pass with .25 end mill
2) Finish pass with .25 ball end mill
3) Finish pass with .020 tapered ball end mill.
The results are fantastic.
Much more detail and cleaner finish.
This is the cutter
JERRAY
TC-R0.5 D1/4" 1-1/4" 3" 2F
scotttarnor
Thank You JERRAY !
Scott T
@scottscnc
Xxray
Post by Xxray »
Jan.vanderlinden wrote:On thing that I have started doing is to make a second finish pass with a smaller cutter and stepover
This is the cutter
JERRAY
Am wondering how results would be different or any better with an extra pre-finish pass. In theory, there shouldn't be any difference.
gkas
Post by gkas »
This is the cutter
JERRAY
+1.
I can't see any way two finish passes over the same material would make any difference to the final result. Rest Machining, yes; this, no.
BigC
Model of CNC Machine: Workbee
Post by BigC »
This is the cutter
JERRAY
Bookmarked
Thanks for the info
Regards
C
Xxray
Post by Xxray »
This is the cutter
JERRAY
+1.
Seems like a waste of time, resources and energy to me but Jan is no novice and produces top notch work, we'll see what he has to say. He does say he reduced stepover and uses a smaller bit on the 2nd finish pass and this of course can make a great difference in detail ,, But this could [should] have been done in the first place, I'm just not seeing the logic, especially since most people look to decrease cutting time, not increase it.
Post by adze_cnc »
If you use Z-level roughing then I can see "2. Finish..." with a large step-over as being a 2nd roughing cut to clear away the bulk of the material for the 020 bit.
If you are using a 3D raster roughing pass then sure #2 is probably superfluous. But, I could imagine many cases where "Z-level" plus the 1/4" ball pass would be quicker than using "3D raster".
Xxray
Post by Xxray »
Well sure, 2nd pass can be looked at as "2nd roughing pass" or "1st finish pass". I have never seen a case where a roughing pass needed to remove more material for a finish bit, in fact I often forego roughing all together in all but the hardest of woods and deepest of cuts. Unless you are using a machine made out of plastic and a bit made in Nigeria, there is IMO no logical/useful reason to add another pass to the process, this is the 1st I have ever heard of it being done which is why I am curious as to why, I grant that maybe I am missing something here.
BigC
Post by BigC »
Forgoing if the second roughing pass is necessary or not and just go ahead with perhaps a smaller roughing bit and then use the tapered ball mill.
A question about the tapered ball mill if I may please,
How exactly would I go about setting one of these up (Tapered Ball Mill) in the Tool Database? (*typical newbie question :oops: )
and are they a useful bit to have to hand.
I may add one of these bits to my Santa List
Many Thanks
Regards
C
There is a tapered ball nose tool type in the list of tools. Click the Add Tool icon in the bottom left and then choose the Tapered Ball Nose from the dropdown that appears in the dialog.
