Ghosted geometry
Ghosted geometry
Postby JimEE » Wed Oct 30, 2019 6:26 pm
I drew some plans that had some circles on it and some how one got put in the middle of my plans. It's got a cross in the middle of it and I can't highlight it to delete it. The other circles on the project highlight and group just fine. When I try to do a tool path the only circle the program sees is the one I can't delete. How do I delete that one circle?
JimEE
Model of CNC Machine: Home Build
Re: Ghosted geometry
Postby mtylerfl » Wed Oct 30, 2019 6:29 pm
Hi Jim,
There are a number of possibilities. Please post your Vectric project file so we can take a first-hand look at it. I’m sure there is a very simple solution and providing your file will save you (and us) some time and guesswork. Thanks!
carvebuddy.com
Postby sharkcutup » Wed Oct 30, 2019 6:50 pm
It may be possible that the circle is on another layer. Toolpath was created for the circle on that layer and that particular layer is now Locked!!!
1st guess
Sharkcutup
Facebook: Hogan's CNC Crafts
V-Carve Pro 9.519
sharkcutup
Postby Adrian » Wed Oct 30, 2019 7:09 pm
JimEE wrote:I drew some plans that had some circles on it and some how one got put in the middle of my plans. It's got a cross in the middle of it and I can't highlight it to delete it. The other circles on the project highlight and group just fine. When I try to do a tool path the only circle the program sees is the one I can't delete. How do I delete that one circle?
Is this what you're seeing?
If so the circle with a cross is the preview of a drill toolpath. Uncheck the box next to the drill toolpath and it will go away. If that's not it please attach the file as Michael says as I can't think what else it could be without more detail.
Postby jay pieper » Wed Oct 30, 2019 8:20 pm
I would bet a dollar to a doughnut, That Adrian is right.
It sure looks like a toolpath for a drill hole to me. That
is why when you try to delete you can't uncheck in your
toolpaths tab.
jay pieper
Model of CNC Machine: laguna swift 4x4
Postby JimEE » Fri Nov 01, 2019 9:00 pm
I saw a post on here somewhere and I tried that and it worked just fine. I put everything on a separate layer except the offending circle then deleted the layer with the offending circle, no more problem.
JimEE
Return to VCarve - General
Users browsing this forum: No registered users and 16 guests
