Profiles and Spirals with a 3/4" Barley Twist bit
Post by Rcnewcomb »
These are 13" 2x2 pine scraps that came off a packing crate. I used a Magnate 7558 3/4" Barley Twist bit.
15K RPM, 60 IPM, 0.1" pass depth
Depth of cut for these pieces ranged from 0.125" to 0.1875"
I did not use a rounding toolpath at all since the profile and spiral toolpaths overlapped each other.
The profile columns took about three and a half minutes. (0:03:30)
The spiral column took about five and a half minutes. (0:05:30)
Re: Profiles and Spirals with a 3/4" Barley Twist bit
Post by Rcnewcomb »
Here is a video of the spiral being carved: Spiral Barley Twist Column
dhellew2
Post by dhellew2 »
More variations of the barley twist. Dale
Young = time, no money
Old = money, no time
Dale
Post by Rcnewcomb »
used a 1" barley twist. around 10 minutes of machine time.
Mark's Wood Chips
Model of CNC Machine: ShopSabre 23 with Rotary
Post by Mark's Wood Chips »
dhellew2 wrote:More variations of the barley twist. Dale
Both of you guy's barley twists are intriguing. I'm struggling with 4th axis work and I notice quite a bit or deflection near the center of the run on smaller diameter parts. Dale's walking sticks are beautiful and I would like to try to make something similar. Dale, could you post a photo of how you deal with deflection on long, narrow parts? Any other hints like tool bits and depth of cuts would be appreciated.
Mark
mark-s
Post by mark-s »
Really like the walking sticks.
Nice work fellas.
mark-s
