Sphere as a rotary job?
Postby jaru-eri » Sat Jul 27, 2019 1:05 pm
Are there any easy ways to set up a rotary job in order to make a sphere in Vcarve pro? Do I need an STL-file or will it be possible to do it in the program?
jaru-eri
Model of CNC Machine: Taig and router, Gecko G540, Mach3
Re: Sphere as a rotary job?
Postby 4DThinker » Sat Jul 27, 2019 8:32 pm
You can do it using the moulding toolpath. A straight line as the guide down the center (equator), and a 1/4 circle vector.
4 inch sphere 4D.crv
(174.5 KiB) Downloaded 38 times
4DThinker
Postby jaru-eri » Sun Jul 28, 2019 11:59 am
The moulding toolpath is new to me so I think I must have done something wrong when I tried this:
Rotary job size is 140mm long and 100mm diameter and the circle is 92mm. I couldn´t use the crv-file you attached on Vcarve.
jaru-eri
Postby Adrian » Sun Jul 28, 2019 12:36 pm
What version of VCarve are you using? That file is VCarve 9.517
Postby 4DThinker » Sun Jul 28, 2019 1:01 pm
Try this file. As the cylinder is 100mm in diameter I set the moulding toolpath to start 4mm below the surface to end up with a 92mm sphere. The equator guide line still has to run the full perimeter (width) of the flat material blank. To leave a connection to the remaining cylinder I used a 1/4 circle arc less a few mm plus a short extension so the 1/4" ball nose bit would go as deep as I wanted it to. This is a .CRV file generated by Aspire 9.0.
92mm sphere 4D.crv
(67.5 KiB) Downloaded 30 times
4DThinker
Postby Adrian » Sun Jul 28, 2019 1:24 pm
Sorry, ignore me. I read the post as you couldn't use the file at all rather than it wasn't the same as the setup you needed.
Postby jaru-eri » Sun Jul 28, 2019 1:36 pm
Adrian wrote:Sorry, ignore me. I read the post as you couldn't use the file at all rather than it wasn't the same as the setup you needed.
I use v 9.517 but when I try to open the file I get the message that aspire files can´t be opened in Vcarve.
jaru-eri
Postby jaru-eri » Sun Jul 28, 2019 1:42 pm
I got the same problem when I increased the guide line. Do you think you can save the file as an stl-file instead? Maybe I then can open it in Vcarve..
jaru-eri
Postby 4DThinker » Sun Jul 28, 2019 2:17 pm
Very Odd. I haven't had anyone ever complain they could open a .CRV file I exported from Aspire unless they were using an earlier version. The only version I have of Vcarve itself is 7.5 but that doesn't have the moulding toolpath in it. At this point I suggest you read up on the moulding toolpath. I can export as a 3D model, but as this is a wrapped rotary job can't advise you on how to import it into a wrapped job and create toolpath for it.
4DThinker
Postby scottp55 » Sun Jul 28, 2019 2:51 pm
Opened fine here 4D,even though this laptop was running VCP9.516 at that moment.
GMH
Postby Adrian » Sun Jul 28, 2019 2:54 pm
jaru-eri wrote:I use v 9.517 but when I try to open the file I get the message that aspire files can´t be opened in Vcarve.
It opens fine for me in VCarve with two different 9.5 versions including 9.517
You should only be seeing that message if you're trying to open a CRV3D file which this isn't.
Postby jaru-eri » Sun Jul 28, 2019 3:09 pm
I tried to open the file directly from the link and that didn´t work, but when I import it inside the program, i get this result, but I couldn´t figure out how to manage it further.
jaru-eri
Postby mezalick » Sun Jul 28, 2019 4:14 pm
Very nice approach 4D,,,Thanks for sharing.
Michael
Michael Mezalick
https://carveddetails.com
mm@mezalick.com
mezalick
Postby 4DThinker » Sun Jul 28, 2019 6:38 pm
jaru-eri wrote:I tried to open the file directly from the link and that didn´t work, but when I import it inside the program, i get this result, but I couldn´t figure out how to manage it further.
Don't import it. Save it to your PC, then File:Open it in Vcarve.
BTW, you shouldn't use it as I made it unless you have a 1/4" ball nose bit with 2" of cutter. Use a larger area clearance tool to remove most of the wood in steps before you run the Swept Profile toolpaths.
4D
4DThinker
Postby jaru-eri » Sun Jul 28, 2019 7:13 pm
I think I´m doing something wrong here. I have tried to click on the lines in different ways, but I just can´t figure out how to do it right.
Here is the result when I opened it as a file:
jaru-eri
Next
Return to VCarve - General
Users browsing this forum: adze_cnc, Google [Bot], Mikehell and 9 guests
