fluting
fluting
Postby NormanAlbert » Mon Jul 22, 2019 9:15 pm
so okay, I knew if I posted the question I would then find the answer. And I did. But is there a way to specify all vectors at once
or must each be selected by itself?
NormanAlbert
Re: fluting
Postby lsvien » Mon Jul 22, 2019 11:22 pm
Check out Paul Rowntree's web site. http://paulrowntree.weebly.com/gadgets.html
He has a gadget to do that called Green Squares. I've used a few of his gadgets and they work well. Smart guy.
lsvien
Model of CNC Machine: Shark
Re: fluting
Postby 4DThinker » Mon Jul 22, 2019 11:32 pm
You can't change the nodes for all the vectors selected unless you find a gadget that'll do that. The fluting toolpath WILL work on all vectors you have selected though.
When I've bumped into the same problem, often it is easier to delete then redraw all the vectors starting each where you want the fluting to start.
4D
4DThinker
Return to VCarve - General
Users browsing this forum: No registered users and 25 guests
