Tiled job with tool changes
Postby rab3rd » Wed Jul 17, 2019 1:53 pm
Hello all, first post here. I have a question regarding tool changes and tiled projects. Lets say two tools and three tiles. will the first tile be cut and include a tool change or will all three tiles be cut with tool one, then start over on tile one with tool two?
rab3rd
Model of CNC Machine: DIY
Re: Tiled job with tool changes
Postby mfirlott » Wed Jul 17, 2019 2:31 pm
All tool changes happen for each tile. In your example...2 tools for tile 1, 2 tools for tile 2, and then finally, 2 tools for tile 3.
(Mitch)
CAMaster Stinger I
Vectric Aspire v8
Epilog 45watt Helix Laser
mfirlott
Postby Samson » Wed Jul 17, 2019 3:25 pm
I would say it would depend on how accurate your positioning is. If it's accurate and repeatable, I would run all 3 tiles with the first tool, and then run all 3 tiles with the second tool.
My reasoning is the DOC variance between tiles, causing additional work to clean it up. If the spoil board and positioning is accurate, the carve will be consistent for each tool change, since the cutter stays static in the collet and the zero remains static.
JMO
Samson
Model of CNC Machine: 4x4
Postby IslaWW » Wed Jul 17, 2019 4:36 pm
Yes, all tools for tile 1, then 2, etc.
The scenario that Samson presents is indicative of another issue.
CNC Technology & Training
IslaWW
Postby TReischl » Wed Jul 17, 2019 4:40 pm
Samson wrote:I would say it would depend on how accurate your positioning is. If it's accurate and repeatable, I would run all 3 tiles with the first tool, and then run all 3 tiles with the second tool.
JMO
That sounds like a good theory. Might even work.
However there is a huge "IF" in that theory:
"If it's accurate and repeatable..."
Moving work is way less accurate than changing tools and rezeroing on the surface.
If a person is using the caveman technique of touching off tools using a slip of paper, etc, then your theory might work better.
Postby rab3rd » Wed Jul 17, 2019 9:01 pm
Thank you, yes I wasnt asking how I should do it,I was asking how Vcarve handles it.
rab3rd
Return to VCarve - General
Users browsing this forum: Google [Bot] and 30 guests
