Two display stands to be made
Re: Two display stands to be made
Postby phill05 » Tue Jul 16, 2019 9:56 am
Hi Scott,
No luck on e-bay, thank you for the offer of the file I guess I have to wait and see what timber I can come up with to fit in to a design yet.
I had to smile when I saw your squirrel (my pet hate is a ******* squirrel) I have a Walnut tree down our garden and last year it had nuts for the first time and I had a battle with the squirrel who got to the nuts first He won.
So I cut a plaque of the tree with my dog watching a cat in the branches watching a mouse in the roots and whilst everyone is watching each other the squirrel is eating my nuts in top of tree, when it's finished going to hang it in the tree for future owners of the tree.
Keep up the good work I look forward to following your postings.
Kind regards
Phill
phill05
Model of CNC Machine: Hybrid re-build
Postby scottp55 » Tue Jul 16, 2019 2:44 pm
Now THAT'S what I call a Tree of Life Phill! :)
BUT it's a lot less reason to hate squirrels than an acquaintance who's shop burned down because a squirrel chewing insulation off his 220V caused some fireworks, or my Dad having to have $2K worth of carpentry/sheetrock work done because a squirrel in the attic managed to find a path all the way to the basement and damaged 2 floors of sheetrock/insulation using the house as an Outhouse! :(
I can see your point though, as the critters barely leave me a mouthful of wild strawberries/raspberries/blueberrys every year :)
DID the missing "S" in the wormy Walnut Branch Stand yesterday.
Only mucked it up a Little:(
Brought the file up, LOCKED the font layer after getting the exact size and options,added an "S" layer with the same dimensions and with a reference line moved/nudged into position.
ZOOMED in and hovered over the corner of the exact last letter carved, moved machine to that position, and dropped the tip of the bit down to roughly position the branch.
Used a machinist square along the carved letters, and gently tightened hold downs.
Rechecked/nudged and then brought bit down by .01" fixed nudging,and then nudged .03" into the wood...rechecked and tightened all the way.
HARD from the wheelchair to look straight down at the machinist's square,especially with the dust foot:(
Lifted the bit flush with the piece,and it still looked good...so did an air cut .02 above surface....it looked a hair off, so Nudged both my X and Y Zero +.005", and then carved.
I THINK when pushed the bit into the wood it slid down the slope of the "A" a hair, OR tightening hold downs all the way?
To my eyeball it looks slightly off :oops:
First time I've had to try this with 2 live edges, and the reference against my Y fence cut off and hand sanded...Close..but had hoped it would be perfect :(
NEXT time...I'll get a mirror and a GOOD flashlight, and my lightest hammer to Nudge the piece better!
HOPING there won't BE a next time, but........... :)
Postby scottp55 » Sun Aug 11, 2019 2:42 pm
Finally got a sheen/feel I liked on hers!
Just have to Goop leather feet in, and then a last beeswax coat.
Postby WNC_Ed » Sun Aug 11, 2019 3:53 pm
Wow, Scott that looks absolutely SPECTACULAR!!!
A museum quality heirloom piece.
Congrats
Maker of sawdust
WNC_Ed
Postby mtylerfl » Sun Aug 11, 2019 9:44 pm
That is gorgeous, Scott!
carvebuddy.com
Postby rtibbs2018 » Mon Aug 12, 2019 11:50 am
Amazing work Scott,
Some day I “Aspire” to get to your level. (Pun intended) :mrgreen:
I am curious about your mounting board. Appears to be some type of camlock?
Ron
rtibbs2018
Model of CNC Machine: Shopbot desktop
Postby scottp55 » Mon Aug 12, 2019 2:42 pm
Thanks very much guys! :D
I think I like it more than the design I was thinking of before I made the Pocket Oopsie:)
I had to get more creative than planned to cover up my mistake :)
Ron...I'm just a VCP guy...I aspire to Aspire too!! :)
Those are Shopfox clamps;
https://www.amazon.com/Shop-Fox-D3347-Cam-Clamp/dp/B00012XE0A/ref=sr_1_5?gclid=EAIaIQobChMIwcyKv7P94wIVjIjICh2r-AevEAAYASAAEgI3zPD_BwE&hvadid=190521513733&hvdev=c&hvlocphy=9002575&hvnetw=g&hvpos=1t1&hvqmt=e&hvrand=9221986390778016116&hvtargid=kwd-302783794464&hydadcr=1611_9901461&keywords=shop+fox+clamps&qid=1565615330&s=gateway&sr=8-5
....disadvantage= very little throw and I was forever shimming with Anything at hand before I discovered that using different wedges(use plywood as alternating grain hold better than solid wood) usually means VERY quick jigging. I have grid of threaded inserts/dowel holes and various fences and corner jigs to usually set-up at 0,0 fences, but can be anywhere quickly with dowel alignment and then a couple bolts. NICE two only need two Allen wrenches:)
Advantage is STRONG wedging power, and they press the material Down as it goes in.
Swap out with same size carrier boards is about 30 seconds :D
I better pick up 2 more while I'm on the page(I gave two away).
Postby Tomg@coj.net » Thu Aug 15, 2019 1:00 pm
I just looked through this and am soooo impressed, really. As a rookie I could ask a dozen questions which I won't do, but would like to ask two:
1. When I have cut a dished out item they seem too rough. I assume this is a tool selection/stepover issue. Can you give me some advice here?
2. I have a problem trying to cut small text. Some advice here would be helpful too. Thanks
Tomg@coj.net
Model of CNC Machine: SharkHD4
Postby martin54 » Thu Aug 15, 2019 4:13 pm
Tomg@coj.net wrote:I just looked through this and am soooo impressed, really. As a rookie I could ask a dozen questions which I won't do, but would like to ask two:
What do you mean by rough? If you mean the top edge where the dish shape meets the rest of the board then that is probably because you are not adding a zero plane when you set up the work in vcarve. Anything that is machined below the material surface requires a zero plane :lol: :lol:
If you mean the actual bowl or dish shape itself then it will be a stepover issue. If you are getting ridges its because the stepover is to large, a ballnose bit has a rounded cutting edge, the larger the stepover the larger this ridge will be ecause of the shape of the tool.
A lot depends on the work you are doing when it comes to sepover, for just a dish shape then anything under about 8% should give a reasonable finish, sometimes you need to step down a little more if like me & Scott you are not a fan of sanding :lol: :lol:
For 3D work my stepover varies from about 3 - 8%, the smaller it is the more machining time it takes. The size of the bit used depends on the level of detail you require. With just a dish shape you can use a large diameter bit but with a small stepover :lol: :lol:
Postby martin54 » Thu Aug 15, 2019 4:19 pm
Forgot about text :lol: :lol:
Small text takes a bit of practice, its really about finding out what works best for your machine, really depends what you mean by small & what sort of look you require, one important thing about small text is it generally requires slowing the feed rate right down, due to all the very sudden changes in direction how rigid your machine is plays a big part in how slowly you need to run to get good results. some woods machine better than others so thats another factor.
Your best bet is to but a couple of decent bits, Scott has some that he swears by & will no doubt add to this, then experiment with speed & feed setting until you feel it's at its best. Start really slowly & build up :lol: :lol:
Postby scottp55 » Thu Aug 15, 2019 6:11 pm
Thanks Martin! :)
WAS right out straight today, and now Bobtail Farm is visiting (Highly anticipated:) with his new pup a day early and arriving around sunset :P
WILL reply when I get some time to think straight! :)
Thanks for the comments Tom:)
Postby WNC_Ed » Fri Aug 16, 2019 12:39 pm
I don't know but would be willing to bet that using "Scott's Super-Secret CNC Sauce" or is it "Scott's Super Secret-CNC Sauce" would help in both cases.
Scott, you really should be selling your secret sauce. :lol:
Maker of sawdust
WNC_Ed
Postby scottp55 » Fri Aug 16, 2019 1:52 pm
Sorry Tom...busy all day yesterday, and only 2 days cutting before too warm to use DC in shop....so sawing and surfacing and baking:)
A dight busy before greenhouse gets too warm to saw.
No secret Ed...musta mentioned the non-toxic recipe we finally came up with for buttons/blocks several times.
It's just Earthpaint Linseed Oil (NO metallic dryers,just purified and semi polymerized for faster drying), and then your choice of the best beeswax you can find..
Double filtered organic(no commercial non-organic farms in 5 mile radius) beeswax(should smell faintly like honey....NOT a chemical smell. Local is best.
Commercially we bought several batches of beeswax Pastilles.....ONLY Peak Candle was good:( (Chemical smells ranged from barely noticeable...to RAUNCHY!)
BUT Peak candles beeswax source dried up...so now they're Peak Fragrance :( :( Luckily I have pounds of stash:)
It WON'T help on 3D's unless Finish pass is .01-.015"......A final Finish pass removing almost nothing is more important. DOES seem to help on Tiny (.1-.2") fonts, BUT slowing WAY down is more important.
In a canning jar, add Oil(Tung works as good or better but gels 10 times faster) to mark (80% oil), then add beeswax chunks(20%), and in a saucepan with spacer to hold glass off pan surface...
(I use a layer of pennies) bring water up to 150F(you can hold your finger in water....HOT but not burning.
Stir until melted.....turn heat off, and stir often until pudding consistency, and throw canning top on.
Correct consistency for me, is a light touch doesn't penetrate...you stick your finger in, and it changes to easily spread warm butter feel.
Wipe/brush ALL excess off after half hour....VIVA paper towels are most absorbent, and least lint I've found.
DO NOT BUNCH UP RAGS and throw away!!! All oils can self combust!!! Lay flat on concrete floor to dry a few days, or a wet pail until disposed of....(OR burn them like I do:)
Gotta get back to see if I can cut this Oak Burl straight.....wicked nervous on this one as I'm still a babe in the woods with burls...especially ones cut in December and wet.
Postby Tomg@coj.net » Fri Aug 16, 2019 10:05 pm
Thank you very much for the suggestions
Tomg@coj.net
Previous
Return to VCarve - General
Users browsing this forum: bpoborski and 39 guests
