Weave affect to Vectors
Postby Marko74 » Mon Jul 15, 2019 12:37 am
I am a Newbe and been plodding through the tutorial videos as well as hands-on in the software. I have been struggling with this project I am currently modeling. This model is a serving tray cut from a blank of 3/4” Maple. There are several toolpaths defined which are working fine:
1. The perimeter of the tray as well as the handle cut-outs.
2. The rounded rectangle which is a simple Pocket
3. The oval shape is a groove modeled as a 2D profile (meant to provide a clean termination of the effect placed within the oval).
I have successfully modeled and cut this serving tray once already while placing a “Swirl” texture within the oval shape.
This tray is different in that instead of the “Swirl” texture, I am trying to cut a “Weave” effect within the oval as illustrated in the tutorial video :Extrude and Weave Guide. And this is the object with which I am having problems: I created a cross section of intersecting lines within the boundary of the oval shape and manipulated those lines by extruding along those lines (vectors) with a simple profile. Furthermore, I used the Weave functionality to create a woven effect for those vectors. I have attached a picture of what the model looks like with the “Weave” selected in 3D view:
I cannot seem to set up an appropriate toolpath to produce the “Weave”. I have tried using the texturing toolpath to no avail. It just cuts a weird texture over the complete screen.
It is confusing to me mostly because the 3D depiction of the “Weave” is not a vector as such. The original lines that I used to create the “Weave” are the only real vectors.
Obviously I need to turn the beautiful "Weave" pattern into appropriate Vectors, then make the necessary Toolpath Operation in order to machine this.
How do I set up a toolpath that will actually cut the “Weave” as depicted in the 3D view? Or perhaps there is a tutorial video that explains this process??
Marko74
Re: Weave affect to Vectors
Postby SteveNelson46 » Mon Jul 15, 2019 12:51 am
Use the celtic weave creator gadget and the extrude weave tool. Then create an oval vector and use the "Clear Area Outside Selected Vector' Tool.
For the toolpath, use a 3D finish toolpath with selected vectors. See pic.
SteveNelson46
Model of CNC Machine: Camaster Stinger with Recoil Lathe
Postby martin54 » Mon Jul 15, 2019 5:16 pm
Once you create the 3D weave it is no longer vectors so you can't use a 2D toolpath to machine it, you need to use the 3D roughing & finishing toolpaths :lol: :lol:
With a shallow weave you probably won't need to use a roughing toolpath just the 3D finish toolpath. :lol: :lol:
Postby Marko74 » Mon Jul 15, 2019 7:46 pm
Thanks for the timely and helpful response. Your directions worked perfectly. I am heading into my shop to start making sawdust. I will gladly post a picture when the tray is finished. Thanks again :D
Marko74
