Problem when combining sweeps
Postby Olle » Fri Jun 07, 2019 1:00 am
I'm trying to combine two sweeps, and it all works like I want it except for one thing: It makes a "perforated" line along the line where the sweeps intersect. The pictures show before and after I change the combine mode, and I have never seen it doing this before. What am I doing wrong?
Olle
Model of CNC Machine: Laguna MCNCIQ
Re: Problem when combining sweeps
Postby Olle » Fri Jun 07, 2019 1:01 am
...seems like I can only attach one picture at a time, so here's the "after" picture. The left component is set to "merge", the right component to "low".
Olle
Postby highpockets » Fri Jun 07, 2019 1:47 am
Can you post the file?
Postby Olle » Fri Jun 07, 2019 2:02 am
Lots of clutter in that model, so here's a file with only those two components.
Pgen2new.crv3d
(1.03 MiB) Downloaded 30 times
Olle
Postby highpockets » Fri Jun 07, 2019 2:10 am
Is this what you're looking for?
Postby Olle » Fri Jun 07, 2019 2:19 am
No, like in the second picture I posted, but without the "perforation". I tweaked one of the sweeps a bit so the components in the file look slightly different in the model, but the problem is the same: A row of holes along the line where the components intersect.
Olle
Postby highpockets » Fri Jun 07, 2019 2:34 am
Don't know, it's a display anomaly, creating a finish toolpath it's not there.
Postby Olle » Fri Jun 07, 2019 2:45 am
No, it's not just the display. I tried to bake the components and smooth it over (see picture), and it made it even more obvious that these are holes. Didn't you see any of this when you opened the file?
Olle
Postby highpockets » Fri Jun 07, 2019 3:06 am
I did, but I didn't bake the pieces, I just create a finishing toolpath of the two components.
Postby mezalick » Fri Jun 07, 2019 9:28 am
I believe it's a combination of a pixelation issue of the components and the subtract low property.
I would like to see the vectors you used to create this sweep.
I "removed" a very small slice of the edge of the problem component and the holes disappeared.
Michael
Michael Mezalick
https://carveddetails.com
mm@mezalick.com
mezalick
Postby Olle » Fri Jun 07, 2019 2:38 pm
That is very strange. My vectors look nice and clean, so I don't understand why this happens. I might just do what you did and shave a few 1/1000" off the edge.
Pgen2newv2.crv3d
(1.23 MiB) Downloaded 25 times
Olle
Postby Adrian » Fri Jun 07, 2019 3:44 pm
In both files you're only using a small part of the material. Aspire is pixel based so you need to have the material size as close to the size of the model you're creating otherwise you're just wasting pixels with all that empty space and not getting the edge quality you could get.
Postby Olle » Fri Jun 07, 2019 4:15 pm
This is actually just a small part of the whole model, so that empty space will be filled later. In any case, just trimming a bit seems to solve it.
Olle
Postby phill05 » Sun Jun 09, 2019 1:01 pm
Create parts of the whole model in smaller material sizes to get the best effect, then bring them all together in the larger material area works every time.
Phill
phill05
Model of CNC Machine: Hybrid re-build
Return to Aspire - General
Users browsing this forum: No registered users and 25 guests
