steampunk desklamp
frank taylor
Model of CNC Machine: bravoprodigy be3030
steampunk desklamp
Post by frank taylor »
made from 6mm and 3mm mdf fully up its 800mm high down 600mm frames painted copper metal and the gears gold has an Edison bulb and a Frankenstein on off switch
Re: steampunk desklamp
Post by mtylerfl »
Another great project, Frank! I love the industrial-look and the Frankenstein switch!
Thanks for showing us the pics!
rtibbs
Model of CNC Machine: Shopbot desktop
Post by rtibbs »
Very. nice work! It’s on my ever growing list of projects :D
Phil
Post by Phil »
Very cool. I think you could sell the plans for that design. I'm sure you have a fair amount of time invested.
Phil :)
SteveNelson46
Post by SteveNelson46 »
Really cool. It should be a great conversation piece.
GEdward
Model of CNC Machine: 24 X 36 3 Axis
Post by GEdward »
Cool indeed! I'm with Phil in thinking you could probably sell the plans for it. It's hard enough to make progress on the bucket list and then I have to add one more.
What program did you use to generate the gears?
frank taylor
thanks men this design I bought of ebay steampunk steel lamp dfx. format to be plasma cut from steel and the gears welded to the axles I added 1/8th slots to the gears and drilled 1/8"dia. pin holes in the bolts to get the gears to rotate also added 1/6th fillets to all of the sharp corners all pieces were cut using a 1/6th dia. straight flute end mill
so go for it men regards frank
rtibbs
Post by rtibbs »
http://frednelsonfabrication.com/steel% ... 20assy.htm
Plans available from Fred Nelson Fabrication
Not intending to hyjack the thread however, there seems to be an interest in this design
