Will you look at this file please?
Postby BarryGilbert » Fri Mar 15, 2019 1:58 pm
Will someone please take a look at this file and see if you can tell me why the "Rays" at the top won't show up when I try to render the cut? I traced the entire image but had to add the rays on my own using the draw line tool. Those rays seem to be the only thing that won't show up on the cut. What am I doing wrong?
Many Thanks
#StillLearning
Kappa Alpha 24x24.crv
(1.04 MiB) Downloaded 50 times
BarryGilbert
Model of CNC Machine: Shark HD3
Re: Will you look at this file please?
Postby garylmast » Fri Mar 15, 2019 2:51 pm
If you V-Carve, it won't recognize open vectors. Try the profile "on" the vectors.
garylmast
Postby BarryGilbert » Fri Mar 15, 2019 2:53 pm
garylmast wrote:If you V-Carve, it won't recognize open vectors. Try the profile "on" the vectors.
Thank you! Any way you can send me a screen shot of what you mean? It's not where I thought to look. Or do you mean to use a profile on the open vectors only?
BarryGilbert
Postby garylmast » Fri Mar 15, 2019 3:10 pm
Select ALL vectors. If you V-Carve, it will ignore any open vectors. All the "Rays" are open vectors. A profile cut will carve all vectors. Depending on what bit you use and the depth of cut will determine the outcome.
garylmast
Postby BarryGilbert » Fri Mar 15, 2019 3:32 pm
garylmast wrote:Select ALL vectors. If you V-Carve, it will ignore any open vectors. All the "Rays" are open vectors. A profile cut will carve all vectors. Depending on what bit you use and the depth of cut will determine the outcome.
Understood...Thank you!
BarryGilbert
Postby adze_cnc » Mon Mar 18, 2019 6:53 pm
BarryGilbert wrote:Will someone please take a look at this file and see if you can tell me why the "Rays" at the top won't show up when I try to render the cut?
The file you posted has no toolpaths so I wonder what "the cut" is? Was it a v-carve/engraving toolpath?
The suggestions so far have been to profile everything on the line. How about this: profile, on the line, the rays only and do "the cut" that you previously mentioned for the rest of the shield.
Steven
Postby BarryGilbert » Tue Mar 19, 2019 2:36 am
Steven
Thanks Steven,
When I changed the rays to a end mill bit .032 they became a tool path even though it kept warning me that they are open vectors. I was attempting to use the V-bit to avoid a tool change. Why will it not work with a V-bit? What is the difference? Sorry, I just don't know.
BarryGilbert
Postby ezurick » Tue Mar 19, 2019 8:34 am
BarryGilbert wrote:Thanks Steven,
Barry, not sure why you are still having issues. First, group the rays separate from the rest of the vectors so it will be easier to work with.... it takes some time, but believe me, it is worth it. Then vcarve toolpath a 60 degree v bit of everything except the rays, with a flat depth of something like .08". Then set a profile toolpath on the rays with the 60 degree v bit of .08" depth. Easy peasy!
I tried to do that and upload it, but it is too large with the toolpaths. This dumb 3mb limitation is ridiculous. I zipped it up and it is STILL too large. So, you'll have to figure it out.
ezurick
Postby BarryGilbert » Tue Mar 19, 2019 11:37 am
Oh no, don't misunderstand, I have already cut it using the instructions you and others provided. I just had to run it as two tool paths. I just didn't understand why the program wouldn't cut an open vector with a V-Bit but does with an end mill. That's all.
BarryGilbert
Postby sharkcutup » Tue Mar 19, 2019 1:35 pm
BarryGilbert,
When using V-Carve/Engraving Toolpath only closed vectors can be used to cut. When using the profile toolpath open and closed vectors can be used to cut. This is the way that V-Carve has been designed by its programmers.
Closed Vector - Is a vector which is a closed vector with no open ends. Example: Circles, squares, rectangles, slots, ellipses, etc... A straight line has open ends it is not a closed vector.
You may use whatever you heart desires on a profile toolpath to achieve the desired affect you are looking for. Example: V-bit for creating the rays (individual lines (vectors)) of the sun.
Try using the profile Toolpath with profile "on" using the desired v-bit you want to use. Be sure to include a desired cutting depth (c) for your Rays!
Hope this explanation helps!
Have a GREAT DAY!
Shark Cutup
Facebook: Hogan's CNC Crafts
V-Carve Pro 9.518
sharkcutup
Postby BarryGilbert » Tue Mar 19, 2019 2:05 pm
sharkcutup wrote:BarryGilbert,
Have a GREAT DAY!
Shark Cutup
Thank you that does help. I see now where everyone is/was telling me that and I guess I had it in my head that profile toolpath meant that it strictly had to be a bit "other than" a VBit. I really do appreciate this help guys. Sorry for being a little dense.
BarryGilbert
Return to VCarve - General
Users browsing this forum: ger21, Google [Bot], phill05, Steve Misher, tomgardiner and 32 guests
