When I save multiple toolpaths for some reason, in this specific case, it is starting with toolpath 4 rather than tool path 1. This causes a very deep initial cut. Has anyone else had this issue? I have used vectric for a few years and never had this issue, I am using a new PC but I am not sure why that would be an issue.
I double checked to be sure I had all 4 toolpaths selected prior to saving.
THanks for the help!
wrong starting toolpath
- Model of CNC Machine: Home Build
Re: wrong starting toolpath
ok so being the first time on a new pc and vectric install it looks like the default is to not have the "output all visible toolpaths to one file" checked. So I was only trying to run toolpath 4 because that was the highlighted toolpath when I hit save....thats annoying.
This is a good reminder to everyone who has reloaded, updated the program. Check all the defaults before running. Where is the z zero, which PP, etc. Been fooled by that a couple of times.
I think it goes further than that Tom, I don't think you should ever take things for granted & relly on the defaults, if you take the time to check through the forms properly each time then you greatly reduce the chance of making any errors.tomgardiner wrote:This is a good reminder to everyone who has reloaded, updated the program. Check all the defaults before running. Where is the z zero, which PP, etc. Been fooled by that a couple of times.
I do that all the time now, yes been caught out in the past myself with upgrading & the home z position resetting to something like 2 inches
I only have 21/4" clearance under my gantry so with those figures I would top the z axis out on just about every toolpath
