Merge stl-files for double sided machining?
- jaru-eri
- Model of CNC Machine: Taig and router, Gecko G540, Mach3
Will it be possible to make a mirror copy of a stl-model like the knife handle below and merge them for double sided maching? Or maybe to a full 3d model for rotary machining?
- gkas
Re: Merge stl-files for double sided machining?
Why not cut the two halves, then glue-up? No 3D assembly required.
- jaru-eri
If I can create a 3D model and use a rotary machining toolpath, I will then avoid damaging the decoration on the sides which can´t be engraved just from one side.
Although vcarve only allows one stl model you can have as many copies of that one stl as you like so yes you can import the one file & duplicate it, for 2 sided machining you just need to copy the component to the other side.
- jaru-eri
I managed to create a two sided toolpath, but I couldn´t change it to a rotary job. Are there any ways to import a two sided project to a rotary setup?
It is possible to export the model as STL and then import than into rotary project.
Greg K
Greg K
- jaru-eri
OK!gregk wrote:It is possible to export the model as STL and then import than into rotary project.
Greg K
But which kind of file type do I need to export it as? I can´t find "stl" as an alternative. And do I need to mark the model on both sides? I couldn´t find a way to do that.
Are we talking VCarve here? You can only export as an STL file from Aspire.
Adrian is right, STL-export is Aspire-only feature. I'm sorry for misleading you, I just didn't notice that it was V-Carve section of the forum.
In your case, there is another workflow possible, that does not require you to go through double-sided project.
I hope that this helps with your project.
Greg K
- Create a rotary job and import your STL model of half of the handle: It should look like this (view from Z axis): From the other side it will look horrible (but we will fix that in a moment):
- In your component tree you should now have your imported model and a zero plane. Right click on the former and select duplicate
- Select the copy of the imported model and mirror it vertically (or horizontally, if you are wrapping around X axis)
- With that component still selected, go to 'Move Selection' form. Select bottom left corner as the anchor, select 'Absolute' as move type and enter x: 0 y: y/2 (press equal here to calculate the formula (if wrapping around x axis use x: x/2 y:0
- Set the merge mode of the component to merge. It should look like this:
- Right click on the level and select 'Wrapping'. Both sides of the handle should be now fully visible
Greg K
- jaru-eri
I followed your plan, and it looked good at the first 3d view, but I got a split in the roughing toolpath. The finishing toolpath calculated more properly as you can see at the pictures, so something doesn´t work as it should.
Edit:
After posting the pictures I´ve found that the same problem also occur with other whole 3d models, so this has nothing to do with only the merged one. maybe there is something wrong with the calculation of the toolpath in my program.
Edit:
In that case please send us your project and STL file if possible to support@vectric.com so we can have a closer look.
Greg K
Greg K
