Mix ratio for sanding sealer?
Postby jaru-eri » Mon Jan 07, 2019 9:34 am
I tried to make a solution with 1 part resin to 2 parts alcohol, but it got very thick like a gelatinous mass. Do I need more alcohol in this solution or do I need to heat it up in order to get it more liquid?
jaru-eri
Model of CNC Machine: Taig and router, Gecko G540, Mach3
Re: Mix ratio for sanding sealer?
Postby scottp55 » Mon Jan 07, 2019 11:04 am
Sanding/Sealer as in 100% wax free shellac? Like Bullseye Sanding/Sealer?
Not understanding the "resin" part:(
Postby tomgardiner » Mon Jan 07, 2019 2:32 pm
It sounds to me like the alcohol is incompatible with the resin. Alcohol works with shellac if it is high percentage. Read the label, your finish may require a proprietary reducer.
tomgardiner
Model of CNC Machine: FMT Patriot 4 x8
Postby martin54 » Mon Jan 07, 2019 2:45 pm
probably need a bit more detail, lots of different types of resin available, I can't think of one that I would mix with alcohol though :lol: :lol: Come to think of it there are also a lot of different types of alcohol available, some almost pure & some with lots of additives.
What is it you are trying to achieve/are you looking to do, I have different types of sanding sealer for different types of work & also dofferent finish coats again dependant on the job or type of finish I want :lol: :lol:
Postby jaru-eri » Mon Jan 07, 2019 6:18 pm
I used wax free shellac and methylated spirit. I need to use it for surface stabilizing before carving in order to avoid breakage at the top of the cuts. I have had the shellac for many years. Can it be out of date?
jaru-eri
Postby Leo » Mon Jan 07, 2019 6:24 pm
Shellac can definately be out of date.
The solvent for shellac is DNA or DeNatured Alcohol
Generally a sealer is a one pound cut. That means one pound of dry shellac flakes to one gallon of DNA. --- that is pretty thin - almost like water.
A three pound cut (3 pounds of flakes to one gallon of DNA) is a finishing cut.
The stuff in the can is already a mix so you would need to know the cut to figure out the 1 pound cut for a sanding sealer. OR you can just buy a can of sanding sealer
www.leosworkshop.com
Leo
Postby jaru-eri » Mon Jan 07, 2019 6:44 pm
Here is a google translate from a norwegian site that describe the alcohol:
Red liquor is 70-95% denatured ethyl alcohol, ethanol. The red liquor is added to a denaturant which makes it useless for food and drink, and often the dye fuksin which gives a reddish color.
So one pound to one gallon is ratio 1 to 8. Then my solution is wrong and I need to mix in more alcohol.
jaru-eri
Postby garylmast » Mon Jan 07, 2019 6:49 pm
Usually it's not recommended to thin resin, but I know for cleaning you use acetone. You might try that instead of alcohol.
Gary
garylmast
Postby ger21 » Mon Jan 07, 2019 6:52 pm
Dry shellac flakes have a shelf life of about 3 years.
Once dissolved in alcohol, the shelf life is about 6 months.
ger21
Postby martin54 » Mon Jan 07, 2019 7:49 pm
jaru-eri wrote:Here is a google translate from a norwegian site that describe the alcohol:
You might want to check what else is in the stuff you have before mixing more in :lol: :lol:
It may contain other additives which give problems with mixing with shellac :lol: :lol:
Return to VCarve - General
Users browsing this forum: Rcnewcomb, tomgardiner and 30 guests
