I use Vcarve 9,5. I have an stl of a cross I made. i wold like to add a
stone like look to parts of it. Is this possible . I part of this is a clip art the center.
Here is a screenshot
Don
add stone look
- Makingtoothpicks
- Model of CNC Machine: Cncrouterparts CPR2448
Re: add stone look
It would be easier to do that in a separate rendering package.
You can at lease show different areas in different colors by creating vectors around the different areas and creating separate toolpaths with their own associated colors.
- Xxray
Re: add stone look
You can create your own textures and merge them with models, sure.
Probably not the "stone look" you are after but for an example, here are a couple of corian hearts I made where the model was just a smooth 3D heart and I added a brick texture. You can use depth to make them more or less prominent, and a host of other things no doubt.
- Makingtoothpicks
Re: add stone look
I only see texture maker as a thing to make textures with.
It appears to only make waves. How do you add a brick
texture to a model.
Don
texture to a model.
Don
- Xxray
Re: add stone look
Haven't done it in a while Don, I'll look into it if no one else replies, I made a post about it years ago but old posts can be tough to dredge up here. Super easy as I recall [once you know how], I made dozens of custom textures and stones should be pretty easy with lots of available material [bmp's].
- Makingtoothpicks
Re: add stone look
Thak you. I will look and see if I can find anything on Utube.
I did get a stone like look using the other program. I wish
I could afford Aspire.
Don
Don
- Xxray
Re: add stone look
Dang didn't notice this was vcarve, my bad - Short answer there is I'm not sure if its possible.
