Just wondering why - for those with too much time
Karl60
Model of CNC Machine: Flat Bed gantry
Post by Karl60 »
VCarve 9.510
Why in the attached crv does the top part cut out but not the bottom part?
Clearly there's room for the tool bit - the top cuts out.
Practically, problem simply solved by increasing the vertical space between the parts or turning off separate last past; but that's not the coffee-time query.
Thoughts?
Karl
(gone for a coffee)
profile test.crv
(34 KiB) Downloaded 153 times
LittleGreyMan
Re: Just wondering why - for those with too much time
Post by LittleGreyMan »
Karl,
This has obviously to do with the allowance. In some parts of the curves, the distance between internal curves is about 6.845 < 6.35 (bit Ø) + 0.5 (allowance).
If you calculate separately the toolpath for each vector, it is OK. If you select both, the calculation probably detects there is not enough room for the tool to cut one part without cutting the other one.
But the result is not totally logical as you get a full depth final pass for one of the parts without the first passes.
Better send the file to Vectric.
Best regards
Didier
W7 - Aspire 8.517
Post by scottp55 »
Changed to a Spiral Ramp changing nothing else, and it cut. Hmm...?
profile test SPIRAL RAMP.crv
(58 KiB) Downloaded 130 times
LittleGreyMan
I don' think so, Scott. If I'm not mistaken you only have 1 pass between the parts.
Time for another espresso? :D
Best regards
Didier
W7 - Aspire 8.517
Post by scottp55 »
Right as usual Didier :oops:
Didn't quite slow the cut down enough in preview, OR check toolpath:(
ODD behavior!
(MAYBE another cup:)
I'm claiming distraction on this one...playing with the pedestal, and almost ready to cut Quilted Big Leaf Maple.
2018-11-02 08_18_32-VCarve Pro - ShopBot Edition 9.510 {Aloka LLC} - 10.30.18 HEART PEDESTAL 2.jpg
joeporter
Post by joeporter »
I think you need a separate toolpath for each part...joe
LittleGreyMan
joeporter wrote:I think you need a separate toolpath for each part...joe
No, if the space between parts is sufficient, the toolpath will be calculated without problem.
If you run 2 toolpath with the original spacing each toolpath will cut a little the other part because of the last pass allowance.
Best regards
Didier
W7 - Aspire 8.517
sharkcutup
Post by sharkcutup »
Change both start points on each section to the top center of each section and re-calculate toolpath.
It cuts the parts out thoroughly but I noticed that the second part the is not necessarily started at the start point. The toolpath reverses direction cuts top section after completing the bottom section.
Here is the file
profile test.crv
(63.5 KiB) Downloaded 116 times
Sharkcutup
V-Carve Pro 12.005
LittleGreyMan
Sharkcutup,
In your file, the separate last pass is reset to 0, so the problem disappears. If you set it back to 0.5 mm as in the original file, it won't cut properly.
Whatever you do, if tool Ø + last pass allowance > distance between parts, it won't cut properly which makes sense.
Karl, still not back from coffee? Better take an espresso than a long one. :D
Best regards
Didier
W7 - Aspire 8.517
sharkcutup
Sharkcutup,
And so it did change the setting on its own, good catch LittleGreymen for I did not see it change, Thank You. So the problem remains unchanged!
I will take the Espresso, Thank You!!!
Sharkcutup
V-Carve Pro 12.005
Karl60
Post by Karl60 »
Back from coffee ....
As far as I can see; the query remains a mystery. It's not a practical problem per se - just a curiosity. Just seemed logical to use a 7mm gap (nice round number) to run a 6.35mm bit up and down. We'll upgrade to 8mm gaps; bigger is surely better.
Onwards.
Thanks.
Karl
LittleGreyMan
Karl60 wrote:Just seemed logical to use a 7mm gap (nice round number) to run a 6.35mm bit up and down.
Yes, but you have a last pass allowance and the gap is less than 7mm in the curved part.
6.35 + 0.5 (allowance)= 6.85 > 6.839
There is not enough space for the bit before the last pass.
But the toolpath is not correct and you'd better send the file to Vectric.
(and take another coffee as I already mentioned that in my first reply :D )
Best regards
Didier
W7 - Aspire 8.517
gregk
Model of CNC Machine: None
Post by gregk »
In addition to what LGM explained, it is worth noting that the allowance is applied to both vectors. So, the correct gap between the vectors have to be at least 6.35 mm + 0.5 mm + 0.5 mm = 7.35 mm
I will see whether we can display a useful error message in such case and fail to calculate the toolpath, rather than end up with a wrong toolpath.
Greg K
LittleGreyMan
Thanks for the feedback, Greg.
I gave a try with a much larger gap, so I didn't notice the double allowance thing.
Karl, back from coffee? :D
Best regards
Didier
W7 - Aspire 8.517
mezalick
Post by mezalick »
Just to revisit this..
24" x 24" material work space.
12" diameter circle position in the center of the work space.
Profile toolpath, cutting on the outside of the vector.
Last Pass Allowance of 0.08" will calculate.
Last Pass Allowance of 0.09" will not.
Michael
Michael Mezalick
mm@mezalick.com
