Pocket accuracy
- Model of CNC Machine: Openbuilds C-Beam
Pocket accuracy
I have been running my CNC with V-carve for some weeks now but mainly tinkering and using MDF with no need for accurate dimensions. The results have been very pleasing.
But, I tried to make an accurate piece out of Corian and my pockets are all under size by approx 1%
For example a pocket 70mm x 40mm came out as 69.3mm x 39.6mm and a hole of 7mm diameter was 6.9mm.
I have a laser attachment on my CNC and by using this I know that the CNC is very accurate. For example a 500mm x 500mm square came out as 500mm x 500mm.
Is there some tolerance setting that I am missing? or could it be to do with the measurement of the tool bit?
Re: Pocket accuracy
It can be a number of things. The bit dimensions could be off, it could be bit deflection or deflection in the machine itself.
Their are no forces involved when using a laser whereas when you're routing there is a lot of force on the bit and on the machine itself.
Try shallower passes and/or reducing the feed rate.
- sharkcutup
Re: Pocket accuracy
Adding to Adrian's suggestion in shallower passes, feed/speed rate
Try ramping into the pockets --- I have found using ramping into pockets tends to eliminate most machine flexing. It adds a little bit more time to your toolpath but the end results is better.
I would also recommend checking the actual bit size too that can sometimes make all the difference in the accuracy of your toolpath.
Sharkcutup
Sharkcutup
V-Carve Pro 12.004
V-Carve Pro 12.004
Re: Pocket accuracy
I always use ramps and a very slow feed rate ( I am in no rush to damage my bits or machine )
I think I can rule out bit deflection or machine deflection because the pockets are extremely accurate and square (albeit too small) Surely if there were any deflection the edges of the cuts would be "wobbly"
Re: Pocket accuracy
Not necessarily as the bit deflection would be constant over the pass.Tony Pagett wrote:I always use ramps and a very slow feed rate ( I am in no rush to damage my bits or machine )
Do a simple profile cut square with the same bit, depths and feed rates. Measure that. Now, with the same vectors, change the toolpath to 0,5mm depth or so so it just barely cuts the surface. If there is no bit deflection or machine deflection then the results will be identical.
Re: Pocket accuracy
I have tried this and the results are identicalDo a simple profile cut square with the same bit, depths and feed rates. Measure that. Now, with the same vectors, change the toolpath to 0,5mm depth or so so it just barely cuts the surface. If there is no bit deflection or machine deflection then the results will be identical.
I have just tried "fooling" the machine by editing the tool diameter. My 70 x 40 hole is now 70 x 40 but this only works with a single tool pocket. If I use a two tool (clearance and final) then the second, smaller bit does not remove any material apart from a very small piece in the corners
Re: Pocket accuracy
What type of pocket toolpath are you doing? If it's a raster have you got a final pass option selected?
Re: Pocket accuracy
I have tried just about every combination (offset, raster, climb, conventional etc etc)What type of pocket toolpath are you doing? If it's a raster have you got a final pass option selected?
I have noticed that the profile tool path is also out by approx 1% making objects oversized (130mm is cut to 131mm). "Fooling" the program again also corrects this.
Re: Pocket accuracy
It is easy enough to validate if the G-code is correct. Draw a square. Do a toolpath ON the vector. The values in the G-code should match up with the square.
Re: Pocket accuracy
Try tracing a very shallow (a few tenth of mm) square with a sharp new Vbit in MDF.
If the size is correct, this is definitely a flexion issue. If not, double check the size of your laser cut.
Coud you post a picture of the machine and the spindle?
Best regards
Didier
W7 - Aspire 8.517
Didier
W7 - Aspire 8.517
Re: Pocket accuracy
Any OpenBuilds machine will have a lot of deflection. They're not that rigid.I think I can rule out bit deflection or machine deflection
Everyone has seen deflection. Even $100,000 routers will have deflection.
As Randall said, check the g-code. The coordinates will be off from the actual position by 1/2 the bit diameter. You'll almost certainly find that there are no errors in the g-code.
Re: Pocket accuracy
Gerry, you ruined my attempt to suggest that in a much softer wayger21 wrote:Any OpenBuilds machine will have a lot of deflection. They're not that rigid.
Best regards
Didier
W7 - Aspire 8.517
Didier
W7 - Aspire 8.517
- Model of CNC Machine: Shapeoko 3 XL
Re: Pocket accuracy
Using a Shapeoko 3XL to make mating box tops and bottoms they did not fit using the same vector to cut both top and bottom (profile on bottom one and pocket on top). I measured them with the micrometer and the top was smaller than the bottom I assume due to deflection. I tried a number of cutting options with little improvement. I ended up adding an -0.015 allowance on both the pocket and the profile cut tool paths and I have a nice fitting box (sightly loose to leave room to apply a finish to final fit).
Gary Mitchell
Kentucky, USA
Kentucky, USA
Re: Pocket accuracy
Something as simple as changing the direction of cut can make a big difference.
Climb cutting will tend to remove less material, while conventional cutting will remove more.
The reason is that climb cutting pushes the tool away from the work, while conventional cutting pulls it into the work.
