Where are the helical post processors?
spyderxxx
Model of CNC Machine: my own design
Post by spyderxxx »
When I watched the new features of 9.5 I was interested in the helical posts. However I cant find them. Is this an Aspire only feature?
Ed
Re: Where are the helical post processors?
You have to edit the post processor yourself to create the sections for helical arcs that relate to your setup or see if there is one available on the support site of whatever control software you're using.
The ShopSabre posts are the only ones I know of that come with the helical arc sections in as standard.
There is a bit about it in the 9.5 is here thread, sure I read another post about it as well but can't find that. If you try a search you may have more luck, I am not that good with searches :oops:
http://forum.vectric.com/viewtopic.php?f=27&t=30471
IslaWW
Post by IslaWW »
For the most part, post processor modifications of upgrades would be handled by the OEM or MFGR of a given machine. Or not, depending on whether that feature is compatible with the controller that runs the machine.
GCnC Control
Tailmaker
Post by Tailmaker »
I added the following 4 blocks to the regular "g-code(mm)" post processor (right before the end section) and renamed the "post name" line. That worked right away. Have not tested it much, though.
+ Commands output for clockwise helical arc move
begin CW_HELICAL_ARC_MOVE
"G2[X][Y][Z][J]"
+ Commands output for first clockwise helical arc move
begin FIRST_CW_HELICAL_ARC_MOVE
"G2[X][Y][Z][J][F]"
+ Commands output for ccw helical arc move
begin CCW_HELICAL_ARC_MOVE
"G3[X][Y][Z][J]"
begin FIRST_CCW_HELICAL_ARC_MOVE
"G3[X][Y][Z][J][F]"
spyderxxx
Post by spyderxxx »
I'll give it a try
Ed
spyderxxx
Post by spyderxxx »
Tried a few times but couldn't get modified file to show in the list of post processors. I sent a request to support and received a working file promptly.
Thanks again
Ed
The list shows the name of the post processor rather than the file so if you didn't rename it by changing the POST_NAME at the start of the file it would have shown up as whatever that name was set to.
