Dividing a circle in segments
- Model of CNC Machine: Heiz High Z Machine German manufacture
Hi Everybody,
Just a very general question .... Is there a quick way of dividing a circle into segments ?
I can do this by dividing 360 by the number of segments required.... then rather laboriously drawing them out .... but do feel there must be a better method.
Your help would be appreciated.
Re: Dividing a circle in segments
I do this by drawing my circle to size then draw a .062 inch circle and use the copy along vector.
Draw one vector from the center, and do a circular copy.
Use the polygon tool. Set the number of sides to how many segments you want. Start it out at the center of your circle, then size it so it touches the circle. Where is touches the circle you can mark or trim or whatever.
4D
4D
I do it the same way as ger21, draw one vector from the middle of the circle to the edge of the circle & then use the circular array tool to divide it into the required number of segments
Thanks to everybody who greatly assisted me with this little problem.
I have been using this programme for several years now and never before had a need for "circular copy"..... worked wonderfully.
I needed to divide a circle into 37 segments
The forum is a great asset
Thanks once again
Thanks once again
- Model of CNC Machine: Shapeoko 3 XL
I've been using line and circular copy like others but I'm wondering if a star with the same diameter would work too.
Gary Mitchell
Kentucky, USA
Kentucky, USA
- SteveNelson46
Something like this?wb9tpg wrote:I've been using line and circular copy like others but I'm wondering if a star with the same diameter would work too.
Exactly what I was thinking but wasn't sure it'd work. Quick and easy4DThinker wrote:Likely more like this:
Gary Mitchell
Kentucky, USA
Kentucky, USA
I am using the circular copy of the line,
What I am actually making is a roulette wheel
The finished Wheel will look similar to this
If I'm not mistaken this one requires 38 segments, not 37.Soapyjoe wrote:The finished Wheel will look similar to this
BTW, using the star feature is a nice trick.
Best regards
Didier
W7 - Aspire 8.517
Didier
W7 - Aspire 8.517
Hi,You are quite correct for an American Roulette wheel.... they give the punters a lower chance of winning by having two Zeros
However, I am modelling a European type wheel with only one zero.
Cheers
Cheers
