Interesting problem
Interesting problem
When I import the model everything looks good.
Smooth edges and lettering. In the 2D layout view this is what it looks like
You can see the roughness on the edges and the lettering. After creating the cutter pathes, my preview shows chattering. When I cut the material, I get the same results as the preview Why is this happening?
Why would my preview not be the same as the original model that I imported?
- IslaWW
Re: INTERESTING PROBLEM
In all honesty I personally would never cut something with that geometry as a 3D model. It would be faster, cleaner and much higher quality to machine using 2D vectors.
GCnC Control
GCnC Control
- highpockets
Since 3-D models are pixel base, at the same time you hit "Create a new file" hold down shift. Then on the modeling resolution you can choose either "Extremely High or Maximum" resolution.
Gary
Gary
As with Gary - I would also do that as a 2D process
When you say 2D, do you mean to stack the vectors?
Yes. That's 2,5D, ie you can break it down into successive 2D operations as the opposite of reliefs that require continuous Z variations.Jan.vanderlinden wrote:When you say 2D, do you mean to stack the vectors?
General rule: if it's not 3D, don't use 3D toolpath.
You can get a nice cut if you have a CAM which provides toolpath for cutting high slope walls, but it will never be as efficient as 2D cuts.
Best regards
Didier
W7 - Aspire 8.517
Didier
W7 - Aspire 8.517
- adze_cnc
If by "stack the vectors" you mean the "stacked text" technique not necessarily but it could be done that way.Jan.vanderlinden wrote:When you say 2D, do you mean to stack the vectors?
Looking at the model and with the right vectors and bit sizes I think this could be done with 4 pocket toolpaths and 2 profile toolpaths. The two profiles are the full-depth final profile pass and around the rectangle that the word "Michigan" sits on. All other levels would be the pocket paths.
Steven
If I was doing this particular model, I think I would model it as mentioned, however, not all times do you want to or can, so you have to import the 3-D model. A quick search found a model similar to yours from Thingiverse. I imported it both standard resolution and maximum resolution. It was a crappy model to start with, so you can't hope for much, but there is quite a difference. Notice around the letters and outside edges. A better 3-D model would give you better results.
Gary
Gary
That would be a fairly simple model to make in 2.5D. Here is a Michigan sign I did awhile back. We did adjust the color of the M after this pic was taken.
Mark
Pioneer, CA
Pioneer, CA
Re: Interesting problem
Thank you all for the input.
I have never built a stacked vector program.
But im going to give it a whirl.
Is there a tutorial on the subject?
Thanks again for the help.
- Vectric Staff
- Model of CNC Machine: Various
Hi Jan,
As all have mentioned here you are going to get far better results approaching this from a 2D machining point of view. The idea is to think of you part in layers, where the word "Michigan" will be at the top (least cut depth) and the Border for the letter M will have the least height and therefore have more cutting depth.
In terms of tutorials there isn't one that deals with an example exactly like yours however you can take a look at this stacked text example: https://support.vectric.com/tutorials/V ... cks_1.html this should hopefully help you understand how to create the different heights between each text entity by using the pocket toolpath and altering the start depths for each height level.
Going forward I have made a note to consider recording a new tutorial using an example similar to yours here.
I hope this helps.
I hope this helps.
Beki
So i watched the tutorial and have been trying to make the 2.5D model.
The first pocket cut with MICHIGAN in the center comes out good.
But when I try to go down subsequent layers, it still blow the center away.
What am I missing?
What am I missing?
- adze_cnc
Have a look at this. My earlier thoughts on toolpaths were not quite right. 3 pockets and 1 profile (with the right vectors) are all that was needed.
Of course, things may need to be altered for your design thicknesses, etc.
Steven
Steven
I can do a pocket cut for MICHIGAN and the first boundary.
But when I try to make the second cut (which would make the large "M") it does not respect the first boundary and completely wipes out the center portion where is says MICHIGAN.
