Apple cider anyone?
garylmast
Apple cider anyone?
Post by garylmast »
I did the Apple as a Double-sided project, but it looked a little lonesome, so I decided to do the Barrel. I had some left over 2-1/4 x 3/4 oak flooring that I beveled the sides to form the barrel, then shaped it on the Rotary.
I have a large rotary that runs the length of the bed, so I use the Y-Axis (wrap X values). When I did the lettering, although in the preview it showed everything was fine, the first attempt machining, the letters came out mirrored. The second time I reversed the letters and they machined correct. If using the X-Axis, there is no problem with the mirroring. I have informed Vectric Support of the problem, so hopefully they can figure it out. I also informed them several months ago, that if a 3-D model has lettering on it, if imported for the Y-Axis, it will come in mirrored. Again the X-Axis there's no problem.
Gary
Re: Apple cider anyone?
Post by highpockets »
Like the barrel very creative. Where did you get the barrel staves pattern?
Thanks for sharing.
mark-s
Post by mark-s »
Nice I like it.
My great grand father was a cooper smith.
mark-s
ger21
Post by ger21 »
Are you sure that your rotary isn't spinning backwards?
dwilli9013
Post by dwilli9013 »
Nice work Gary as always. Thanks for sharing. I like the vase next to it as well. Your home must be a verifiable showcase of all of your pieces. :lol: :lol: :lol:
D-Dub
Dwayne
Dwilli
garylmast
Post by garylmast »
Thanks everyone for the replies
I cut fifteen oak strips to a width of 2" and beveled each side 11.7° on the table saw, when clued together, created the full circle. I drew the curvature in Rhino giving me about 1/4" thickness at each end and just under 3/4 in the center.
That's the first thing I check and that's not the problem. If I import (Y-axis only) it looks good on the input page, but when I accept the part, it will come in mirrored.
Anyway, Vectric Support has been made aware of the problem, so until then, I got to remember to mirror the letters before I machine them.
