Creating New Brush Tool
ger.wat
Model of CNC Machine: ShopBot PRSAlpha
Post by ger.wat »
I need to create a Brush Tool for deburring. Since there's not a category/tool type for that I tried using End Mill but have found I can't set the speed anywhere near slow enough. I could if I were making a drill but then I couldn't use it on a traveling toolpath. Too many restrictions. How do I get around these restrictions to make a traveling tool that can run at 300 - 2000 rpm?
jerry
Re: Creating New Brush Tool
Not sure I follow what you are saying, what is stopping you setting the speed at what ever value you want ?
What are you using to cut ? A router or a spindle ? A high speed spindle probably won't start at such a low speed & even if it does it won't have enough torque to cut butter (warm butter at that ) :lol: :lol: :lol:
At what point are you not able to set the speed? VCarve will let you set the RPM to anything you like so I'm presuming it's an issue when you go to run the actual file which would be your control software not VCarve.
Post by mtylerfl »
ger.wat wrote:... How do I get around these restrictions to make a traveling tool that can run at 300 - 2000 rpm?
jerry
Do you have to override the ShopBot factory programming to get the spindle to run at those low rpm's? (If I recall, I think the lowest rpm I can set is 5K)
ger.wat
Post by ger.wat »
jerry
ShopBot Support was wondering the same thing. As it turns out I'm not getting 300 anyway, I just enter a speed of 300 in VCarve and the Variable Speed Drive, Yasikawa 1000, on my ShopBot outputs 4260rpm. So I merely assumed it was running 300 but no, it's 4260, a somewhat arbitrary number that the drive comes up with somehow as a compromise between my 300rpm input and what is "supposed" to be the slowest, which SB told me is set at 6000.
So I'll just have to work with that.
