End Grain inlay question - challenge
- jssussex@gmail.com
- Model of CNC Machine: Legacy Maverick 3X5
I'm trying to help a friend out on an end grain cutting board that he wants to inlay this image.
I was gong to do an MDF test but then since the cutting board is 1 1/2 inches and he would like to do a 1/2 thick walnut end grain inlay I decide I'd ask the experts here their opinion before I damage a beautiful end grain blank. Also what glues do you use for endgrain. all my experience is in shallow flat grain decorative inlays.
The problem is that the facial detail is so fine I don't believe I can successfully carve this. The facial outline is only .046 wide. I was gong to do an MDF test but then since the cutting board is 1 1/2 inches and he would like to do a 1/2 thick walnut end grain inlay I decide I'd ask the experts here their opinion before I damage a beautiful end grain blank. Also what glues do you use for endgrain. all my experience is in shallow flat grain decorative inlays.
Jim Sussex WI
Heritage Carving and Woodworking
Legacy Maverick 3X5
http://www.heritagecarving.com
Legacy Maverick 3X5
- Model of CNC Machine: 2 SCM Routech Record 120s(1999, 2001)
Re: End Grain inlay question - challenge
Reduce the detail but keep the theme/idea, I agree that you will have problems with this inlay is set up currently
- scubanimal
- Model of CNC Machine: Stinger1 24, Shark HD2 Pro, Aspire,
Given its a cutting board, and the details of the face being thin, but just the face outline, I might consider using an endmill and going a bit deeper and using an dyed epoxy or something for the fine facial features, then the walnut for the rest.
just a thought,
Ian
just a thought,
Ian
I've read several tips and all say that no epoxy is truly safe on a cutting board.
Works for an area you know the knifes will not cut into it though.
Agree with Potzmannwoodshop, a reduction in the detail, replace some of the thin lines with stylized wider paths, be creative. Cold be cool.
Best Luck
Best Luck
- highpockets
Trock wrote:I've read several tips and all say that no epoxy is truly safe on a cutting board.
Best Luck
There are several direct food contact, FDA approved epoxies on the market. There is at least one that is completely organic. Absolutely no VOC's, no chemicals, etc.
- mtylerfl
I wouldn't be cutting on the "pretty side" anyway!
I would cut food on the plain backside only so I don't destroy the design.
Thanks this helpshighpockets wrote:https://theepoxyexperts.com/shop/adhesi ... t-coating/
Jim Sussex WI
Legacy Maverick 3X5
Legacy Maverick 3X5
- Mike-S
Wood filler (Minwax) can be used on end grain as well as regular grain.
- Model of CNC Machine: salecnc XJ1224
I think you might be surprised at the sort of detail you can get with a v-carve inlay. Have a look at mtmwood and his inlayed cutting boards, the main problem with end grain v carving is having the male inlay chipping with the finer detail. I find that by reducing the cutting angle to say 30 degrees on fine detail your inlay has more depth and better glue area (also easier to chip I suppose).
Practice pieces are always the best way of testing your designs.
regards
Brian
regards
Brian
- weirdbeard
- Model of CNC Machine: Jcut
Im with Brian
I did this with 30 degree vbit
http://forum.vectric.com/viewtopic.php? ... lit=aussie
(If you have a look you can see the cross at the top of the crown )
