I trying to run this file. however, each time I run the file, about 50% into the run, the z height rises to a height that does not meet the material. any thoughts?
Games of Thrones Clock
Re: Games of Thrones Clock
What does the preview show in that area?
That usually happens when the machine loses steps, and thus, loses position.
The model appears to have something in the upper right quadrant between XII, I, II, and III that might be "spikes". Roll the model over in Preview to see what that stuff is, and how high it is relative to the numerals. You might need to use a zero plane to limit how high they are if it is what I think it is.
CarveOne
CarveOne
CarveOne
That’s a neat model - is that available somewhere?
- Model of CNC Machine: bravoprodigy be3030
it looks like the clock is in the wrong place it should be down lower in the circle can you share the model
another thought the clock maybe on another layer check your layers and turn of the clock layer
Bound to be some sort of copyright on something like that so probably not a good idea to try sharing it, having said that there seem to be plenty of people selling it for next to nothing if you look in the usual places
