Grbl support
Tony Pagett
Model of CNC Machine: Openbuilds C-Beam
Grbl support
Post by Tony Pagett »
In Cut2D I use Grbl (mm) (*.gcode) as my Post Processor.
In the trial version of Vcarve this option is not there.
Does it appear in the full version?
If not, are there any suggestions which Post Processor I should use?
vgraves
Model of CNC Machine: CNC Router Parts PRO4848 w/LinuxCNC
Re: Grbl support
Post by vgraves »
I don't remember all the restrictions on the trial versions, I know they limit what files you can actually machine, but I wouldn't think they'd restrict what machine you cut them on. Can you copy the post processor file from your Cut2D PP folder to the Vcarve Trail PP folder?
Re: Grbl support
As far as I am aware the trial versions are the most upto date software & include a full list of supported machines. If the Post Processor you require is not in the list then your best bet would be to contact Vectric Support or if your machine has a forum you might be better asking on there as the chances are someone will have one :lol: :lol:
