Cheaper bits vs Onsrud, etc
Mikehell
Model of CNC Machine: eBay special China 3040
Post by Mikehell »
I can get bits on Amazon or eBay that are cheaper. How much better are the more expensive (Onsrud) bits? Will an Onsrud stay sharp longer than a comparable cheaper bit? Any particular brands to avoid?
4DThinker
Re: Cheaper bits vs Onsrud, etc
Post by 4DThinker »
The reason I buy Onsrud bits is that in my experience that are always the size they claim they are. I've had bits from other manufacturers that came nowhere near the dimensions they claimed. 3/16" is .1875, but one 3/16" whiteside upcut end mill I had alway resulted in loose joints. I finally measured it and found it was .1904. That explained why tenons turned out smaller than expected, and mortises were larger than expected.
4D
Leo
Post by Leo »
I use SGS a lot. I know it's not well known around the hobby world or the wood world but it is a high quality cutter and VERY well known in the machining world.
I get SGS from "Carbide Depot" dot com. Generally in the $teens$ per 1/4" cutter
SGS is a quality tool. --- generally made for the metal cutting industry
Onsrud is also a quality tool. --- generally made for the wood cutting industry
There are a lot of differences between a low end tool and a quality tool. There is nothing visibly different to the untrained eye, but to an experienced eye, there is much to be seen. Quality of the grinding and sharpening is visible to the experienced eye. Low end cutters will not be up to the same standards as a high end cutter.
Other things that are not visible at all is the quality of the material the cutter is made out of. "CARBIDE" may seem to be just "CARBIDE" - but in reality it is NOT. Carbide comes in many different grades just like steels do. In steels there is Cold Rolled Steel and there are tool steels. You would not want an end mill made out of CRS - but M42 would be good. Carbide is also available in different grades. Low cost cutters, may or may not be quality carbide. High quality cutters are more likely to be good carbide grades.
OK - so - with all that being said - I have and still do use some of the lower cost cutters, with decent results. There is a noticeable difference in cut quality, and longevity of life.
sharkcutup
Post by sharkcutup »
I agree with both Leo and 4DThinker - (well said guys).
You know the old saying 'you get what you pay for'. I have also used cheaper bits and have noticed a difference in the quality of the carvings too. Cheaper bits are great for roughing carved models or even the final cutouts in which tabs are removed and the entire outside surface is sanded anyhow. Of course this also depends on each individual's preferences final product quality too!
I do recommend that when buying the cheaper bits be sure to check the bit dimensions before adding to tool database. These bits are usually the bits that didn't make the Quality cut at the manufacturer but are still saleable bits in another market.
Sharkcutup
V-Carve Pro 12.004
Ton80
Model of CNC Machine: Shapeoko 3XXL / Carvewright RevB
Post by Ton80 »
I have used Precisebits. I like them because the bits are very good quality and they list all the required info for entering their bits into Vectric software. Sometimes that info seems hard to come by?
Check them out at http://precisebits.com
sharkcutup
Just been to their site and the very first thing I had noticed is that they do not mention whether their end mills are up-cut or down-cut end mills. These type of bits do make a difference with their application!!!
Sharkcutup
V-Carve Pro 12.004
Post by adze_cnc »
sharkcutup wrote:Just been to their site and the very first thing I had noticed is that they do not mention whether their end mills are up-cut or down-cut end mills.
Sharkcutup
I just had a quick look at their site and all the pictures I saw were of up-shear cutters. I'd expect that to be "the default" and any mention of down-shear to be an exception.
Post by Rcnewcomb »
For production work the job is quoted to include the price of the bits.
I am fortunate to live near an Onsrud distributor who offers me good discounts on some of the more obscure bits (odd sizes) that he has to stock, but for which there is little demand.
Centurion Tools makes some top-notch bits, i.e. you can run them for a long time.
For my own experimentation I will also try out lesser-know/unknown brands and sources. There are some good values to be found.
Seller drillman1 on eBay has some good selections. There are many online sources that may be a good value.
potzmannwoodshop
Model of CNC Machine: 2 SCM Routech Record 120s(1999, 2001)
Post by potzmannwoodshop »
4DThinker wrote:The reason I buy Onsrud bits is that in my experience that are always the size they claim they are. I've had bits from other manufacturers that came nowhere near the dimensions they claimed. 3/16" is .1875, but one 3/16" whiteside upcut end mill I had alway resulted in loose joints. I finally measured it and found it was .1904. That explained why tenons turned out smaller than expected, and mortises were larger than expected.
4D
Gage R&R, measure every tool when it goes into a tool holder to verify.
Post by scottp55 »
+1 on Drillman1 on his Kyocera 1/8" shank bits.
And love my Centurion FEMs.
I DO have a bunch of cheap Amazon and EBay bits that will probably sit in the back of the drawer forever after using them ONCE however.
Don't think I'll ever swap away from my Onsrud engraving bits though...find what works for YOU...and stock up:)
ger21
Post by ger21 »
Another +1 for Drillman1. With small bits you can get good bits for very low prices.
But once you get to 3/8"-1/2" bits, I only buy high quality bits.
Mikehell
Post by Mikehell »
ger21 wrote:Another +1 for Drillman1. With small bits you can get good bits for very low prices.
I get all my 1/8 bits from drillman1. His selection of larger (1/4 and above) is a bit limited though. But the Onsrud bits he does have are priced good. One thing I do like about Onsrud is that I can look up chip load in the back of the catalog.
