no toolpath generated
I have been trying to create a profile toolpath to cut this pattern out. the board I am using is big enough for the .25 em to travel all the way around, but it keeps telling me . check tool can fit into selected vectors at machining depth. I don't understand what is going on. please help.
- New shelf.crv
- (17.5 KiB) Downloaded 97 times
- highpockets
Re: no toolpath generated
You don't say, but if you're running VCP 9.x use Vector Validator on the vector.
In the upper cut to the left of the half circle you have an "Intersections" that's causing the problem. Use node edit to fix the problem.
thank you so much, I have been trying everything I could think of. I am very new at this and really appreciate the help.
highpockets wrote:You don't say, but if you're running VCP 9.x use Vector Validator on the vector.
just wanted to say thanks again, that fixed it. all of us that are new at this appreciate the help
- highpockets
Glad it worked out.
Happy to help. We all need help from time to time, that's the great part about this forum.
