Proto-type Gumball Machine
Postby sharkcutup » Fri May 25, 2018 2:57 pm
Proto-Type Gumball Machine
Needs a little tweaking --- Ramp is too steep sometimes Gumball bypasses the mark! --- Also need to look into gumball sizes because the small gumballs drop two at a time causing the gear to jam.
But overall not a bad proto-type gumball machine!!!
Sharkcutup
Facebook: Hogan's CNC Crafts
V-Carve Pro 9.517
sharkcutup
Re: Proto-type Gumball Machine
Postby highpockets » Fri May 25, 2018 4:33 pm
Looks great can't wait to see the finished project.
Thanks for sharing....
Postby lsvien » Sat May 26, 2018 3:02 am
Once you have it working, want to share your file?
Lawrence
lsvien
Postby watsonswords » Sun May 27, 2018 3:42 pm
Looks awesome so far! Looking forward to the finished product.
Tom Watson www.signsinwood.com
watsonswords
Postby JoeinWestMich » Sat Jun 02, 2018 3:00 am
Keep up the tweaking. Please post the final working model. We "old" gumball lovers are eagerly awaiting the final workings!
JoeinWestMich
Model of CNC Machine: ShopBot Buddy 48T PRS alpha HSD 2.2HP
Postby sharkcutup » Thu Jun 07, 2018 3:48 pm
Just got finished this morning making some minor adjustments to the proto-type Gumball Machine.
Here are some of the things I adjusted and/or changed.
1.) Reduced gears from 3/4" thickness to 1/2" (Holes in inner part of gears for gumballs were allowing two gumballs to drop at a time causing the gear to jam against jar lid)
2.) Cut down top support board from 3/4" to 1/2" plus a little to match gear sizes and allow a little gap for ease of movement of gears.
3.) Cut dowel supports for top board to size.
4.) It was too late for the proto-type but on the production model I am lowering the ramp on the ramp board so the gumball doesn't travel so fast to the pit.
Note: You probably could use this gumball machine for Jelly Beans, M&M's or Skittles just have to make necessary sizing adjustments on the inner holes of the big gear.
After making the necessary adjustments the proto-type gumball machine functions flawlessly!!! Now on with some production models!!!
Sharkcutup
V-Carve Pro 9.517
sharkcutup
Postby RebeccaJ » Wed Jun 13, 2018 8:45 am
This is pretty neat! Thanks for sharing this with the world!
You'll have to create a video of the finished part in action so we can all see! :)
Beki Jeremy
RebeccaJ
Model of CNC Machine: Various
Postby sharkcutup » Wed Jun 13, 2018 12:50 pm
WOW! This is truly an honor to have a project recognized by a Senior Application Engineer from Vectric, Ltd.
Unfortunately, I cannot take full credit for the original design for it was created by another individual. I had found the photo of the gumball machine on the internet and took the time to draw it out into V-Carve Pro v8.5. But I will say that it was amazing how easy V-Carve makes the design drawing and tool path process. In fact, I believe that it may be time for me to finally make that bold monumental jump to V-Carve V9.
Rebecca Thank you for your kind words!!
I will have to set aside some time in my busy schedule to create a short video of the gumball machine in action to post on You-Tube with link to it here on this thread.
Everyone Have a Great Day!!!
Sharkcutup
V-Carve Pro 9.517
sharkcutup
Postby ctbjdm » Wed Jun 13, 2018 1:03 pm
This looks great @sharkcutup! I showed my kids and they now want me to make one! Are you planning on sharing your design?
ctbjdm
Model of CNC Machine: TBD
Postby sharkcutup » Wed Jun 13, 2018 1:32 pm
I guess now I will have to go into the file and create it in a way for everyone to understand and post it here on this thread! The answer is yes in time I will see that it gets posted.
In my one of my previous posts I said I had made adjustments to the gear thickness sizes and the gear area support board. After researching gumballs I have found that there are various sizes of gumballs out there on the market. In knowing this you could actually create the gumball machine from all the same size material and purchase the gumballs to size to match the machine. I had no idea that the gumballs come in so many different sizes!!!
Sharkcutup
V-Carve Pro 9.517
sharkcutup
Postby ctbjdm » Wed Jun 13, 2018 4:13 pm
Thank you! I’d be happy to contribute to your gumball fund for your efforts...
ctbjdm
Postby sharkcutup » Wed Jun 13, 2018 9:43 pm
With my six grandsons all wanting gumball machine the contributions would definitely be appreciated!!!
I will keep you posted here on this thread when I have the file ready.
Thank You!
Sharkcutup
V-Carve Pro 9.517
sharkcutup
Postby sharkcutup » Thu Jun 14, 2018 4:20 pm
Check out my NEW Website (http://www.hoganscnccrafts.com) which is under construction the gumball machine files are there with the featured products. Be sure to browse around the website a little! Just remember to be patient and to be aware that I am adding to this website daily until I am satisfied with it.
If you have any problems (cause site is NEW) be sure to leave a message on this thread and I will look into it.
Thank You for your Interest!!!
Sharkcutup
V-Carve Pro 9.517
sharkcutup
Postby ctbjdm » Thu Jun 14, 2018 4:29 pm
Sent - thank you! Will let you know how it turns out and provide any feedback. May be a few weeks, have some paying projects first.
ctbjdm
Postby sharkcutup » Thu Jun 14, 2018 4:50 pm
ctbjdm,
Thank You for your Generous contribution/donation. It will definitely satisfy my grandsons appetite for gumballs!!!
Have a GREAT DAY!!!
Sharkcutp
V-Carve Pro 9.517
sharkcutup
Next
Return to VCarve - Gallery
Users browsing this forum: joeporter and 17 guests
