Help with a Fish
- Model of CNC Machine: Industrial 8x4
Help with a Fish
I need some help to carve a 2d fish with a 1/2" x 90 V-bit
I tried the profile tool path on a few fish and they look allfull
Attached is my sign, and the fish will be under the Curries
Thanks for any help on this
- Curries sign with fish.crv
- (683 KiB) Downloaded 138 times
- adze_cnc
Re: Help with a Fish
1. File has no vectors for the fish
2. I'd either use "of" or "OF" preceding GUELPH---definitely not "Of".
Try a depth of 1/32" (0.3125") for the fish profile. That will give a 1/16" wide line with the 90 deg V bit.
Steven
Steven
I took the fish out of the drawing, still trying to draw a fish, and its still looking bad.adze_cnc wrote:1. File has no vectors for the fish
Steven
Thanks for catching that "Of mistake.
Hoping someone may have a fish file I could squeeze in there
Cheers
Ok I got the Fish back in there again
set at .3125
Its looking a bit better now
Plus I fixed the "OF" ... Thanks
set at .3125
- Curries sign with fish 2.crv
- (731 KiB) Downloaded 130 times
You might have more luck if you post a picture or screenshot of the sort of thing you are looking for, haven't looked at your file so don't know if there are any clues in the file but there are a lot of different types of fish
Thanksmartin54 wrote:You might have more luck if you post a picture or screenshot of the sort of thing you are looking for, haven't looked at your file so don't know if there are any clues in the file but there are a lot of different types of fish
- Mike-S
I think Steve meant .03125" The fish looks a little deep now.
Ok now we got the fish swimming not too deepMike-S wrote:I think Steve meant .03125" The fish looks a little deep now.
set at .03125
- adze_cnc
How about a sign with a muskellunge? Do they have muskies in the Speed river?
How about doing a 3d fish.
The Bass which comes with the VCarve programme is quite good.
Make it any size you want and you could screw it from the back.
Kevin Clayton
Kevin Clayton
