I want to create a new folder in Clipart.
That I have managed, however when I try to add content to the folder, it is visible only as long as the media is still attached to the computer.
When I remove the media, the folder is empty.
How do I loads the clipart so that it is always available, without having to attach for the external diskdrive first?
My internal drive is large enough to handle it.
I cannot find a tutorial that describes it.
Clipart
- Ms Wolffie
Clipart
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
Re: Clipart
It has to be on a drive that is active and loaded to be visible. So in your case you would need to create the folder on your internal hard drive and put the clipart in there.
- Ms Wolffie
Re: Clipart
Thank you Adrian
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
