Postby Rcnewcomb » Thu Apr 19, 2018 11:08 pm
Tutorial Videos
Postby lockeb » Mon Apr 30, 2018 8:25 pm
i am looking for some assistance on feed and speed for 1/2 round nose carving in 3/4 plywood. depth .25 inches. i also have 1/4 inch round nose if it will work better.
I'm attempting to make a spiral design on a 20 inch serving tray for may Grand daughter's wedding.
Her design request.
lockeb
Model of CNC Machine: Shark Mako HD
Postby Creation in Wood » Mon Apr 30, 2018 8:49 pm
1/2" BN 2- flute cutting, 3/4" plywood using .022 Chip Load = 180ipm @ 15,000rpm
1/4" BN 2- Flute cutter, 3/4" plywood using .010 chip load = 200ipm @ 10,000rpm
Thank You
Creation in Wood
Postby lockeb » Mon Apr 30, 2018 11:17 pm
Thank You!
lockeb
Postby Adrian » Tue May 01, 2018 8:13 am
Seems a pretty fast feed rate for a Shark type machine.
Postby Creation in Wood » Tue May 01, 2018 2:33 pm
I agree, but I was not told which CNC manufacturer. I run a Maverick, which I would turn up to 300ipm, the sweet spot.
Thank You
Creation in Wood
Postby lockeb » Wed May 16, 2018 2:58 am
Sorry, I have a shark mako cnc w router. So I need to slow it down?
lockeb
Postby lockeb » Wed May 16, 2018 3:05 am
I made a much simpler tray, or 16 simpler trays.
lockeb
Postby 1jonboy » Sun Dec 16, 2018 6:18 pm
Hi I just bought a new piranha CNC fx and I did opt for the laser attachment. However, other than the booklet that comes with the laser I'm not finding much support videos for the laser. I know it is capable of actually creating a laser photo quality sketch. Any info on creating vectors for the uploaded photo or design would be awesome. Thanks, Jon
1jonboy
Model of CNC Machine: Pirhana fx
Postby Aaron Laverty » Wed May 01, 2019 1:38 am
I am new to cnc, have done several carves using easel, but would like to learn to download files and import into vcarve, learn how to carve them.
Aaron Laverty
Model of CNC Machine: x carve
Postby Rcnewcomb » Wed May 01, 2019 2:19 am
Postby Shoekel » Fri May 03, 2019 5:44 pm
I am using vcarve pro and when I design a part to be cut out, occasionally it will cut 1 line on the inside of the line and then the next line is on the outside.
How do I fix that?
Shoekel
Postby Adrian » Fri May 03, 2019 6:16 pm
Shoekel wrote:I am using vcarve pro and when I design a part to be cut out, occasionally it will cut 1 line on the inside of the line and then the next line is on the outside.
How do I fix that?
The vectors are open. If they're meant to be closed then you can use the join tools to close them. If they are meant to be open then you can change the start node on the vectors that are cutting the other side or create two toolpaths with one inside and one outside.
Previous
Return to Cut2D - General
Users browsing this forum: CrowsWW and 5 guests
