Touch plate on the Piranha
mickey222
Model of CNC Machine: Piranha
Post by mickey222 »
Where does the touch plate connect to the Piranha ? It looks like it could be the controller or the display. Thanks for any help.
nicksilva
Model of CNC Machine: ULS M300, Rockler 60th Ann. Shark
Re: Touch plate on the Piranha
Post by nicksilva »
Right here:
"Out of my mind. Back in 5 Minutes."
mickey222
Post by mickey222 »
Thank you.
What is the jack on the side of the controller for, do you know??
mickey222
Post by mickey222 »
Sorry, I meant on the side of the display panel
nicksilva
Post by nicksilva »
sorry don't know. But if you post this same questions over at the shark forum,
Tim Owens from nextwaveautomation will often chime in.
mickey222
Post by mickey222 »
The touch plate does not work plugged into the controller, it needs to plug into the small display. The system does not see the touch plate plugged into the controller but works just fine when plugged into the small display unit.
nicksilva
Post by nicksilva »
well then that means the plug in the controller will be for the digital probe.
creativescrollworks
Model of CNC Machine: Piranha LX
Post by creativescrollworks »
Where is the touch plate placed on the material?
Depends where you want the z zero to be. If you have z zero set to Material Surface then a touch plate is placed on top of the material. If it's set to Table Surface then it's placed on top of the spoilboard.
creativescrollworks
Is it placed at the XY datum?
