Medallion
Medallion
Postby Mobius » Thu Apr 19, 2018 3:04 am
My uncle sent me an image of a necklace medallion that struck true with him, and he wanted a 2' diameter version of it. I was able to adapt the image into something I could cut on the CNC, and it turned out pretty sharp.
He originally wanted it cut from 1/4" aluminum plate, but that ended up being a ton of work with all the tiny details. In the end I made him 4 MDF copies (still took 3 hours each), which he intends to paint/airbrush and give to his wife.
The first two images are concept drawings I made in Fusion360. The rest are the final MDF copies, drawn and toolpath'd in V-carve Pro.
Connor Bredin
www.distinctive-concepts.ca
Mobius
Re: Medallion
Postby ricphoto » Thu Apr 19, 2018 3:11 am
That's really cool...like how the MDF held the edges and detail...Nice job
ricphoto
Model of CNC Machine: Axiom A8 Pro+
Re: Medallion
Postby mark-s » Thu Apr 19, 2018 3:43 am
That`s really nice....good job
mark-s
mark-s
Re: Medallion
Postby rgerding » Thu Apr 19, 2018 4:13 pm
Really impressive.
Ron
If sawdust were gold, I'd be very rich
rgerding
Model of CNC Machine: Iconic 2015
Re: Medallion
Postby Leo » Thu Apr 19, 2018 4:17 pm
Love it - Nice job done well
www.leosworkshop.com
Leo
Re: Medallion
Postby dwilli9013 » Thu Apr 19, 2018 7:10 pm
Very nice. Thanks for sharing.
D-Dub
Dwayne
Dwilli
dwilli9013
Re: Medallion
Postby mick40 » Thu Apr 19, 2018 9:35 pm
Can you tell us what cutters you used? For MDF to hold the detail and not rip out your doing something the rest of us would like to know about. Beautiful!!!!
Mick
mick40
Re: Medallion
Postby LittleGreyMan » Thu Apr 19, 2018 10:31 pm
mick40 wrote:Can you tell us what cutters you used? For MDF to hold the detail and not rip out your doing something the rest of us would like to know about. Beautiful!!!!
Mick
Agreed!
I hate machining MDF and I am always amazed by such machining quality.
Best regards
Didier
W7 - Aspire 8.517
LittleGreyMan
Re: Medallion
Postby Mobius » Sat Apr 21, 2018 2:22 am
Mick
Thanks all.
I used a 1/16" tapered 3 flute EM for the detail, and a 1/4" 3 flute EM for the rest. There were 3 layers (0.5mm, 1mm, 1.5mm), done with offset pocket toolpaths.
I find the trick is in the order things are cut. The fine details on the top gears were cut first, and I skipped the clearance EM, using the 1/16" only.
The rest of the top layer and the two following layers were cut with both EMs. However, I moved the 1/16" finishing passes to the top of the list, so they all cut first and then the clearance passes cut second. Aside from minimizing toolchanges, I believe this is what let me cut fine detail without tearing.
I also hate MDF, I wish I could afford to stock HDU for something like this. It was crazy watching how fuzzy the cut would get the further into the sheet it would go (how less dense the MDF is in the middle, even in 1/4" material).
Connor Bredin
Mobius
Re: Medallion
Postby Xxray » Sat Apr 21, 2018 4:03 am
Dang, looks sharp good job.
I'd spray it down a few times with clear coat, lightly sanding in between coats, to minimize absorption when finish is applied - MDF can soak up finish like a sponge.
Seems to me insulation foam board would be a great candidate for this, very cheap, holds details incredibly and easy to finish.
Downsides are, very messy to work with and very fragile.
Corian too, might be a bit of an expense though if you don't have any handy.
But looks like mdf worked out very well in this case.
Xxray
Re: Medallion
Postby LittleGreyMan » Sat Apr 21, 2018 12:09 pm
Thanks for the comments.
I do agree: toolpath order is a major parameter for machining complex designs in this kind of material or in wood.
HDU or solid surfaces as Corian are much more easier to machine.
Again, incredibly sharp job with MDF.
Best regards
Didier
W7 - Aspire 8.517
LittleGreyMan
Return to VCarve - Gallery
