Best bit for milling corian
mark-s
Post by mark-s »
What is the best bit to use when working with corian
mark-s
Re: Best bit for milling corian
Post by mtylerfl »
Same bits you use for wood, no problem.
mark-s
Post by mark-s »
up cut recommend?
mark-s
Xxray
Post by Xxray »
Any good sharp mill should do, corian machines beautifully.
Might have to pay attention to RPM until you zero in on the sweet spot, you'll want to be creating chips not dust.
If you get dust that means either the bit is not sharp, your RPM's are not optimal, or both.
I go by pitch so can't really tell you what I use - Feed speed could be a factor as well depending upon what you are doing.
ger21
Post by ger21 »
I use the Vortex 4233 for Corian, and it works really well.
kp91
Model of CNC Machine: Digital Wood Carver
Post by kp91 »
V bits work great, end mills seem to work better because no grain to worry about. Can be messy, and needs good dust collector
1 John 1:9
Fredericksburg, VA
mark-s
Post by mark-s »
Thanks for the info fellas.
I like the look of that Vortex 4233 bit, so ordered one.
I work with acrylic alot so might give it a test on that.
mark-s
