Hi All,
I am looking for a post processor for Cut 3D to use with my Fanuc controller.
The post processor that is in my version of V Carve Pro works fine with my Fanuc controller (it is called Fanuc0i ATC (inch) (*.tap) however the one that is in my version of Cut 3D does not work, it is simply Fanuc inch (*.tap)
Can I possibly load the processor from V Carve Pro into Cut 3D? Or is there possibly an updated Fanuc post processors for Cut 3D that I could try?
thanks
Post Processor
Re: Post Processor
Can you import the 3d image into VCP and pick your post-processor then? That's what I do with 3d files I work with. Other than that you may want to contact Vectric support.
Re: Post Processor
You can copy the PP from VCarve to Cut3D but you'd almost certainly have to edit it to remove the sections that aren't supported by Cut3D.
If you have VCarve you can either import the 3D model directly or toolpath it in Cut3D, save the Cut3D file and import into VCarve. That will create all the toolpaths directly in VCarve and you can then use the correct PP there.
