Modify material position
cingolo
Model of CNC Machine: home made project
Post by cingolo »
Good afternoon
How can I change the position of the model in the workipiece once the project has been created? :?:
I do delete all and restart? :(
thanks
Remenber ! A good sharp for a good mill!
joeporter
Re: Modify material position
Post by joeporter »
Double click on the model and you will see a set of "Handles" grab the center one and move the model where you want it. You can also resize the model up or down with the upper left handle and hold "Shift" and stretch or shrink...joe
Original Position
Original Position
New Position
New Position
Larger Size
Larger Size
If you want to move it precisely you can also press the M key and enter absolute or relative co-ordinates.
cingolo
Post by cingolo »
thank you at all
the last question; if I want to move on Z axis? :?:
see image
thanks
my problem
my problem
Z is basically the thickness of the part. You can't do undercuts so you can't have a piece off the base.
cingolo
Post by cingolo »
Thank you at all! :D
