Draw Text in Gadget
- Model of CNC Machine: ShopBot D2418
Draw Text in Gadget
I've built a gadget to help reduce steps and to gain precision and time. I've gotten the lines drawn, now I would like to add some text to the layer I've drawn into (ala Draw Text tool). I don't see anything in the API documentation about this. Is it possible to do from a Lua script?
Re: Draw Text in Gadget
Most of the Gadget API is for vector and toolpath creation; they do not in general duplicate the built in tools such as manipulating text.
Pity.
Cheers!
Pity.
Cheers!
Paul Rowntree
- jimandi5000
Hi There,
I write full lines of test with my gadget.
Send me a emal message at james.l.anderson@outlook.com
Jim
Jim
Jim
Jim
- jimandi5000
- jimandi5000
Here is the current copy of the code.
- TextWriter.zip
- (2.39 KiB) Downloaded 373 times
Jim
Jim
- jimandi5000
- TomWS
- Model of CNC Machine: OB Lead 1010, Mach3; OB C-Beam 1060 grbl
I happened on this thread as I'm looking at an application that requires me to engrave approximately 180 name cards for place settings at a wedding reception. I figured LUA script should allow me to use a name list as input to generate a sequence of VCarve operations to do the carving in the font of choice (Bride's prerogative, of course).
I downloaded Jim's code and was surprised that it didn't use DrawText operations, but created simple stroke vectors for each character. Well, that's a great tool, but not what I need.
Has there been any progress on this such that the VCarve text tools can be used in this case?
- FixitMike
Check the Plate Production tool. It is in the bottom line of drawing tools. See Help-Help Contents for instructions.
As Mike says there is a tool in VCarve to do this already so you don't need a gadget.
Here's a video that shows how it works - https://www.vectric.com/support/tutoria ... ral_Topics
- TomWS
Thank you very much Mike & Adrian! This tool is very useful as well as cleverly named to hide it's function!
I'll have to play with this to see how I can adapt my 'production' model to fit its process. My original thought was to use precut name tags with a jig on the CNC router where I'd place a tag, one at a time, press a key, and that tag would be custom engraved with the next name in the list. I suppose that the plate production tool could be used to make multiple sheets and a LUA script could load them one at a time, but that seems a bit unwieldy.
I would welcome any suggestions you might have, but, this helps a lot and I'm sure I'll figure something out.
Actually, it seems that it would be very easy to use the 'cutout' layer to make a jig to hold my precut tags and use a slightly smaller version of that to hold the tags in the first jig. Then the process would be:
1. Load up the jig with blank tags,
2. tie down the hold down jig on top of that,
3. Cut the sheet,
4. Remove the tags and repeat.
Easy peasy!
Thanks again!!!!
3. Cut the sheet,
Easy peasy!
Thanks again!!!!
- jimandi5000
CNCDaveToo wrote: ↑Thu Jan 25, 2018 3:58 amI've built a gadget to help reduce steps and to gain precision and time. I've gotten the lines drawn, now I would like to add some text to the layer I've drawn into (ala Draw Text tool). I don't see anything in the API documentation about this. Is it possible to do from a Lua script?
Hi Dave,
Have you looked at my "TextWriter.zip" code? I show how to set layer Name, Color, etc... in the code.
Jim
Jim
