Coconut Palm
powair7s
Model of CNC Machine: Home Build
Coconut Palm
Post by powair7s »
Has anyone tried milling coconut palm? I tried today and it didin't turn out well. I used a .25" EM at 40 IPM and a cut depth of .125". Have any of you had success with a different bit? I was trying to do a Prism but any narrow pieces chip off. See the photo below.
dhellew2
Re: Coconut Palmhttp://forum.vectric.com/viewforum.php?f=3
Post by dhellew2 »
Coconut palm is very brittle.
I've had good luck using 3-flute spiral solid carbide bits [www.cuttingtoolsource.com]
I run rpms at 18-22,000 and feed rate 40-50
When possible avoid square corner cuts that go across the grain, if possible extend the cuts past the corner
This works with red oak too
You can do this by making cross cuts first [use layers so you can create separate tool paths]
If 3d carving try to follow the grain just like you would on a planer, jointer, or hand plane [avoid running the cutter cutting into the end of the grain]
If your wood is really dry you may need to first soak with wood hardener, peg, penetrating sealer, or etc.
I sometimes dilute wood hardener so it dries slower and penetrates deeper
Good Luck, the character of the wood is worth the effort
Dale
Young = time, no money
Old = money, no time
Dale
Re: Coconut Palm
Post by Rcnewcomb »
That is great advice and well worth the time for certain woods.
powair7s
Re: Coconut Palm
Post by powair7s »
Wow thanks for the great advice. I will certainly look into the wood hardener.
So on my cutting use more of a raster path to cut along the direction I want to avoid spintering?
Have any pictures of your coconut palm projects?
I also picked up some leopard wood, purple heart and padauk. The place I went had 140 different species, it was pretty awesome.
wbrock
Model of CNC Machine: piranha fx
Re: Coconut Palm
Post by wbrock »
i'm by no means a wood expert, more of a wood collector and I've never heard of coconut palm, i know different wood will go by different name in different regions. I have heard of red palm and black palm. Red palm comes from coconut trees and black palm is from a type of grass cluster. To me it looks like you have black palm. if that is the case then it will be next to impossible to keep it from splintering.
Savannahdan
Re: Coconut Palm
Post by Savannahdan »
wbrock, You might want to do a search regarding Coconut Palms. As to working with palms, a trick I used for turning these for pens was to use superglue. It also works wonders on corncob pen blanks. Be sure to have plenty of ventilation.
powair7s
Re: Coconut Palm
Post by powair7s »
Superglue in what way?
Re: Coconut Palm
Used to do that when turning spalted beech. Soak the wood in superglue, let it dry and then machine. A less smelly and cheaper way is to use a wood hardener meant for rotted wood.
