I have a file I created/cut in ASPIRE (.crv3d), and want to import it to a V CARVE Pro maker's space addition. It does not show up in the list of importable files? I went to "import" as well as the "modeling tab" with no luck. So any help here, seems like it should be possible being an .crv3d file. Help seems to say it's possible, so I must be doing something foolish. Any help?
Thanks in advance.
Importing files
Re: Importing files
It's not an export option, think it comes under "save as" once you select that click on the file type & you should have the option of CRV3D or CRV
Just remember that any 3D models won't save to the file
Just re read your post, vcarve won't open crv3d files, you need to save it as a crv file & then it will open in vcarve
bit about models still applies
- mtylerfl
Re: Importing files
You cannot import a crv3d file into VCarve.GaryR6 wrote:I have a file I created/cut in ASPIRE (.crv3d), and want to import it to a V CARVE Pro maker's space addition. It does not show up in the list of importable files? I went to "import" as well as the "modeling tab" with no luck. So any help here, seems like it should be possible being an .crv3d file. Help seems to say it's possible, so I must be doing something foolish. Any help?
Thanks in advance.
