how can i make wooden tapered pegs w/out a lathe
Postby parentsdisapointment » Tue Dec 26, 2017 12:06 pm
first..............Merry Christmas all
I'm looking to make some wooden pegs in a balloon shape [hope that makes sense].....the holes are .25 dia and would like them about 1.5 inches high or so but not sure how to do them.
I did make some that were round but I didn't like the look. they were .25 for the stake part and .5 for the top part.
mine look more like land mines
I'm looking for more of a look like this
lil help
Model of CNC Machine: piranha
Re: how can i make wooden tapered pegs w/out a lathe
Postby Phil » Tue Dec 26, 2017 2:28 pm
Buy them.
Phil
Postby mtylerfl » Tue Dec 26, 2017 3:20 pm
Phil wrote:Buy them.
Agreed.
carvebuddy.com
Postby 4DThinker » Tue Dec 26, 2017 3:26 pm
If you can start with a cylindrical dowel and have a way to clamp it so the end is up then it is not hard to taper the end. Once tapered remove and cut off the peg, then stick the dowel back in and taper the new end. Repeat until you have all the tapered pegs you want. If you precut the dowel into peg lengths then just stick them into a tight hole with the end you want to taper sticking out. Taper, then remove and stick in the next peg blank. You might need a way to loosen then tighten the hole's grip on the pegs.
Tapering can be done with the fluting toolpath and a circular array of short vectors,
or the moulding toolpath with a profile view of the taper and a circle to use as the drive rail,
or using a tapered end mill and a profile toolpath. You can find tapered end mills in a variety of taper angles.
4D
4DThinker
Postby highpockets » Tue Dec 26, 2017 3:55 pm
Buying them is the most prudent way to go, but if you're looking to make them out of a special material you could try using the double sided job type and molding toolpaths. The banding on the top part would have to be done by hand with a drill or something.
Postby 4DThinker » Tue Dec 26, 2017 4:15 pm
You can do a row of pegs using a strip of endgrain hardwood and any of the three strategies I mentioned above. If you want a step in from the taper then move the tapered path inward.
Render from Aspire:
4DThinker
Postby martin54 » Tue Dec 26, 2017 10:48 pm
Not something I have tried but if you were doing something like a row of them as 4DThinker has suggested then a straightforward profile cut outside a circle might work, just use a dovetail bit instead of a straight endmill :lol: :lol:
Personally I think I would probably just buy them, seem to be quite a large range available & they are not expensive compared to the time it would take to make them :lol: :lol:
I have a wood lathe & would still probably just buy them :lol: :lol:
Postby Timvmax » Tue Dec 26, 2017 11:04 pm
Timvmax
Postby parentsdisapointment » Fri Dec 29, 2017 12:27 pm
Thanks everyone for your suggestions. I think I will try both the double sided job type and molding toolpaths and the dovetail. I know it would be easier to purchase them but I want to go w/the what I produced out of cherry. it has an old fashioned look and I want to keep the peg idea in the same manner. I want to at least "try" new things so I can get some experience under my belt
side note............my parents probably would have suggested to purchase them also....... but you know me........I have a reputation to keep up :lol: :lol: :lol:
Thanks again, all very good ideas
