I am considering buying a 4x6 machine with vacuum table.
I made a mistake once and bought an inferior pump.
For this table they use 2 pumps.They sent me a photo of the label, as far as I can see, this is what it says.
2.2 Kw
50 Kz
155 m3/min
31 kg
220 V
2700 l/min
-34 Kpa
For those in the know, is that big enough?
TIA
Vacuum Pump
- Ms Wolffie
Vacuum Pump
Cheers
Wolffie
Whatshammacallit
Wolffie
Whatshammacallit
- Model of CNC Machine: Axiom Elite
Re: Vacuum Pump
You might want to check with an electrician, I think it might run hot since we have 60 Herz in the US
Re: Vacuum Pump
Wolffie is from a land down under ...cascayou wrote:You might want to check with an electrician, I think it might run hot since we have 60 Herz in the US
Paul Rowntree
Re: Vacuum Pump
I take it the table is zoned so each vac pump covers half the table
Have you got a link if you are buying this from a company ???
Oh good to see you back posting
