V9 Gadgets NOW AVAILABLE
Postby seanm » Thu Jul 27, 2017 10:36 am
The Gadgets Website has now been updated so that you can now access all your favourite gadgets for your V9 software.
Simply go to the Gadgets website as normal and click on the "Gadgets Library"
http://gadgets.vectric.com/index.html
The way gadgets are packaged and installed has changed to make it much simpler to install.
They now come packaged as a .vgadget file and there are two simple ways to install them.
1. Download to your PC and double click to open. This will automatically open up your installed software whether that be Aspire, VCarve Pro or Cut2D Pro V9 and install it directly into the software for you.
2. If you already have the software open, you can install the gadgets directly from the Gadgets menu, just click on "Install New Gadget" and navigate to your downloaded .vgadget file.
If you are looking for previous versions of the software gadgets, these can still be found at the link below
http://gadgets.vectric.com/V8/library.html
The Vectric Team
seanm
Square Around Not working
Postby CNCGG » Mon Dec 04, 2017 2:45 pm
I cant get square around to install with version 9.012 64bit. It does not show up top let me pic it.
It is listed as a .lua file.
Thanks !!
CNCGG
Re: V9 Gadgets NOW AVAILABLE
Postby Adrian » Mon Dec 04, 2017 3:35 pm
Do you did download and install it as a vgadget file?
I've just tried it and it installed and worked the same as the other gadgets.
Postby garionh » Thu Aug 23, 2018 8:42 am
Hey,
I'd like to use http://gadgets.vectric.com/circle_resize.html in V Carve Pro V9, but it says it only works with V8 and v8.5. Any chance of a gadget upgrade?
thanks
garionh
Model of CNC Machine: CNC Router Parts 4'x8'
Postby seanm » Thu Aug 23, 2018 10:10 am
Hi there,
it appears you have stumbled onto the v8 link for the gadgets, Here is the link for all v9 gadgets, you will find the circle resize gadget and all of the others here too
http://gadgets.vectric.com/V9/library.html
Hope this helps
Sean
seanm
Postby davidp » Mon Sep 10, 2018 6:12 am
Hello Sean,
I have just upgraded to VCarve 9.507 and the apply toolpath template gadget causes a "fatal error".
I use this gadget every single day, it is the most useful feature of VCarve (well almost). Will the gadget be upgraded? If not I will have to go back to V9.0.
David
davidp
Model of CNC Machine: Shopbot PRS
Postby Adrian » Mon Sep 10, 2018 8:31 am
It's the code that works out the post processor to use that is failing (local default_pp = toolpath_saver.DefaultPost) and causing the crash from what I can see.
I hard coded the default post processor into a copy of the gadget and it then worked ok.
Return to Gadgets - General
