Dovetail Gadget
mike.mills
Model of CNC Machine: Shopsabre Pro408
Dovetail Gadget
Post by mike.mills »
I am trying to get the dovetail gadget to work so students can come in and use the CNC router to make dovetails.
I am having a few issues with the gadget and program
I use the gadget to create the dovetail pin patterns
Then I use the pin tool path creater
Then I create a tool path to clean out the pin middles
When I turn on the two tool paths together and zoom in you can see that they do not line up. this is creating a little bump in the back of my pin socket
Here are my settings in the gadget
Please help
Re: Dovetail Gadget
Have you tried adjusting the cut allowance? I normally have to tweak that to get a good fit. These dovetails will never be as clean fitting as proper ones due to the way they are made.
mike.mills
Re: Dovetail Gadget
every thing fits nice an snug except for the little bump on the angle cuts. I think if I mess with the allowance or settings the joint will get sloppy.
Thanks Mike
