Need help with egg tray project please
My wife has asked me to make some egg trays for family similar to this
https://ligneus.co.uk/wp-content/upload ... g-tray.jpg
I am not sure how to achieve the best way of cutting the egg shaped recesses, can anyone give me a hint at the best way so I can develop this further?
Thank you!
Thank you!
Re: Need help with egg tray project please
Use one of the dome/dish clipart models that come with VCarve and set the model to be subtracted then 3D toolpath it. It can also be done with a series of fluting toolpaths and I suspect with a moulding toolpath too but I haven't used that enough to be able to say 100% without being at my design computer.
Of the three strategies that Adrian mentioned, the recently added Moulding tool path will likely be the most efficient solution. It is a little tricky to set up for bowl shapes, but only requires a tiny circle and a 1/4 circle/arc for the bowl profile. If not too deep you can probably skip the larger area clearance pass.
- dhellew2
Here is an 18-egg holder
Send me a pm with your email and I will send you the .crv3d or .crv file
The file is 12 meg so I cannot post it
Dale
Dale
Young = time, no money
Old = money, no time
Dale
Dale
- adze_cnc
My question would have to be does the egg-holder necessarily need a concave inner surface at all? You're unlikely to find a dozen eggs with exactly that curvature so it can't be for support of the eggs.
Would it not be easier to have a shallow pocket instead? The pocket doesn't have to be very deep. The Toshiba BC-310 egg cooker in the image is quite shallow and the eggs don't touch the heating surface.
Steven
Steven
- Model of CNC Machine: Axiom AutoRoute 6
Could I get a copy of the files for the 18 egg holder please?
My email is:
pjblues1@neo.rr.com
Thanks.
My email is:
pjblues1@neo.rr.com
Thanks.
- Model of CNC Machine: Homemade
While we are on the topic of the egg tray project (and apologize in advance if this is considered hi-jacking the thread). My significant other had a similar request earlier this year (those catalogs do get around). I made several (12, not 18-egg trays). However, to avoid the undesirable effect (see attached rendition) from the toolpaths I created, I had to do a work around while machining. I recognize this is my error, or at least lack of sufficient understanding. And while the work arounds worked around and avoided the undesireable result shown in the depiction, I expect that there is a correct way I should be creating the tool path leaving an elegant machining operation (without using any one of several work-arounds). I have v-carve pro, and used the 90 degree dome models to create the project, stretching the height appropriately. Created the rough and finish tool paths, using a 1/2 spiral and 1/2 BN, respectively.
Thanks.
Brian
Thanks.
Brian
- Machined using "work-around". there are several ways to avoid the unwanted cut depicted in the other "photo". Here, the finish path was set with a minus 0.25" offset, and I "faked" the Z setting when maching the finish path by seeting it at minus 0.25. Figure there is an elegant (e.g., correct) method.
- mtylerfl
Hi Bob,
It may be simply that you didn't use the Zero Plane in your layout. A Zero Plane eliminates the chatter around edges of recessed dishes.
There are a couple Vectric tutorial videos that will explain the process for you. Go to the Training video page and do a search for "Zero Plane".
Thank you Michael for the pointer. Will do.
Brian.
Brian.
- Model of CNC Machine: Shopbot Desktop max
HI,
Could you also send that .crv file to connal308876@gmail.com as well. This is fantastic:-)
- dhellew2
Do you have Aspire or V-carve Pro?
What version do you have?
Dale
Dale
Dale
Dale
- Model of CNC Machine: Shark Pro HD
Dale, your 18 egg tray looks great. Thanks for posting it.
I don’t appear to be able to send a PM on this forum. Would you be able to send me the V-carve file as well? I am using the latest version of V-Carve Pro (9). This looks like an interesting project and would provide a great starting point for some other dish shaped projects i’ve Been thinking about but haven’t figured out yet.
mcsteve at hotmail dot ca
