File showing contents
Fleming
Post by Fleming »
I have noticed an inconsistency in whether my Aspire files show a preview or not since I upgraded recently to Windows 10 and Aspire 9. Some files generate a preview for the files (Extra large icons is turned on) whereas others do not. Do I need to change a Windows 10 setting or Aspire setting to make sure a preview is generated?? Related, when I save an Aspire file is there a logic I need to be aware of as to when Aspire generates a preview and how it chooses between generating the preview from the 2D or 3D window
Thank you for any insights as to how this feature works.
Paul
Re: File showing contents
What are you seeing on the files without a preview? An large Aspire icon or a blank? Are they newly created files or ones that were created with a previous version and resaved?
Have you tried re-installing the thumbnail extension? That usually sorts out preview problems. Run the VectricShellSetupExt file in the Aspire program folder.
Fleming
Post by Fleming »
Seeing the Aspire logo. Ran that extension file and all is now well :D
Thank you for your help :!:
