Pockets not deep enough
Daner
Model of CNC Machine: Industrial 8x4
Post by Daner »
Good day,
Im running into some problems here, and I cant see what im doing wrong.
Im pocketing a round hole
trying to go 3/4" deep, and there all coming out about 3/8" deep :shock:
Im setting my 1/2" endmill on top of the material.
Its making 2 passes
Thanks for the help
Danny
2.25 pocket.crv
(49 KiB) Downloaded 97 times
4DThinker
Re: Pockets not deep enough
Post by 4DThinker »
It looks like your CNC has the Z axis travel per revolution set to 1/2 of what it should be The file looks normal and should be cutting .75" deep.
It might be that you are using the wrong post processor. Z values may being scaled wrong as they are processed.
Check both things.
Daner
Post by Daner »
Please point me in the direction of Z travel per revolution
My pp is set to Mach 2/3 inch
It's part of the setup of the machine in Mach3. Tell your machine to move a certain distance using Mach3 only and measure the actual movement. If they're different then that's your problem and it's a Mach3 setup issue. If it's the same then the issue is elsewhere.
usLEDsupply
Model of CNC Machine: Digital Tool CNC Router + Speedy 400 120
Post by usLEDsupply »
it's east to check
just zero the bit on the material then move it up until the DRO says 1.00 then measure the distance it went up with a ruler and see if it is close to 1" if not you will need to calibrate the Z axis
Daner
Post by Daner »
Perfect
Thanks guys, I will check that tomorrow
Daner
Post by Daner »
Thanks guys, It was that Z set up that needed to be ajusted.
Running fine now!
