Xps foam
Xps foam
Postby lik2waterski » Wed Nov 08, 2017 4:03 pm
What is the best product to use to fill voids in the pink Xps foam from Home Depot?
Thanks for any suggestions.
lik2waterski
Model of CNC Machine: home made 5x10
Re: Xps foam
Postby jimwill2 » Wed Nov 08, 2017 6:01 pm
Pick up a can of spray insulating foam... might work.
Jim Williams
jimwill2
Model of CNC Machine: CaMaster Stinger w/recoil, FTC
Re: Xps foam
Postby Rcnewcomb » Wed Nov 08, 2017 7:15 pm
Depending on what you are doing Apoxie Sculpt might work for you.
Re: Xps foam
Postby lik2waterski » Thu Nov 09, 2017 2:08 am
Thank you for the suggestions.
lik2waterski
Re: Xps foam
Postby mikeacg » Fri Nov 10, 2017 2:28 pm
I use the foamboard adhesive PL 300 to fill holes. I drill a bigger, round hole and fill it with a foam dowel (easy to make on the drill press). Only need glue in the bottom of the hole and any paint will hide the seams. Plus it sands like it is all one piece. The problem with epoxy type products is that they get hard and sanding is difficult. Spray foam works pretty good and you can build it up in layers but I hate to start a can just for a minor use and end up throwing it away if I don't use it all before it hardens...
Mike
mikeacg
Return to Aspire - General
Users browsing this forum: No registered users and 20 guests
